585,992 active members*
5,159 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    May 2009
    133
    AlphaCam V5 post for Mach 3
    Hello everybody.... Im looking for a Alphacam V5 postprocessor for mach 3. Any help would be greatly Appreciated. Thanks.
    Jan 2006
    114
    Question
    i'am looking alsofor this!
    Somebody??
    Pierke
    Apr 2010
    89
    Re: AlphaCam V5 post for Mach 3
    I could write one for you if you like as I've written quite a few post for our machines in V5 but never for a Mach machine so I'll need an example program with all the relevant code (i.e. cycles, program start/stop, tool calls, movements G0, G1, G2 etc).
    Regards,
    Frank
    May 2009
    133
    So.... you just need an nc file that ive successfully cut on my machine to go by? Thanks.
    Apr 2010
    89
    Re: Alphacam V5 post for Mach 3
    G'Day Mike,
    Could you run the attached nc program file Temp.txt (AlphaEDIT opens .txt files) and let me know how it runs on your m/c and what changes need to be made to the post processor.
    Import attached .dxf into Alphacam to view material size. All geometries are cut so material possibly needs to be larger (depends on how you hold it).
    1st tool 1/8 flat slot drill,
    2nd tool 1/8 ballnose needs to have tool radius in tool offset 12 as it uses cutter comp,
    max depth of tools is Z-0.15625
    Regards,
    Frank.
    Attached Files Attached Files
    Jan 2006
    114
    Smile
    Hello Frank + Mike,
    i'v try the program, but Mach has a problem with the beginning rulers (rem)
    When i remove this rulers, the program runs almost to the end, the rule G91 G28 X0 Y0 (machine zero point),gives a problem, he keeps running.
    It looks that it works well.
    What next?
    Thank you,
    Pierke
    Apr 2010
    89
    Re: AlphaCam V5 Post for Mach3
    Hi Mike & Pierke,
    I've attached two basic post processors for the Mach3 controller, one Imperial (Inch) & one Metric, They work fine with all the tool paths I've tried with them in AlphaCam.
    Just open them up in AlphaEDIT and then File>Save As Post>Mill or Router.
    I've got the post to place an M0 m/c stop at the end of each tool for manual tool change in the router but I've left the M6 auto tool change in the post as I noticed that a tool change request can be set to be ignored in the Mach3 controller (in Configure>Logic) then M6 has no effect.
    Don't hesitate to contact me if any changes need to be made or if you need a more advanced post with extra options like User Cycles etc.
    Regards,
    Frank.
    May 2009
    133
    Hello Frank,
    The Post is working like a charm!!! Im very happy with it and I really Appreciate your time and help! Thank you, Mike :-]
    Jan 2006
    114
    Smile
    Hello Frank,
    the postprocessor works geat. Is its possible to make a few changes?
    Thank you
    Pierke
    Apr 2010
    89
    AlphaCam PostProcessor Mach3
    G'Day Pierke,
    I'm happy to do whatever changes you want, Let me know what needs to be modified or added.
    regards,
    Frank.
    May 2009
    133
    Hello Frank & Pierke...
    I was just wondering what kind of changes were made? Thanks.
    Apr 2010
    89
    AlphaCam post processor for Mach3
    Hi Mike,
    No changes made yet, Pierke has not yet replied with changes he want's made.
    Frank.
    Apr 2010
    89
    AlphaCam Mach3 Post
    Hi Mike,Pierke,Darian,
    Some new posts with a few small changes as noted in Edit History at top of Post, Two without program comments for earlier versions of Mach3.
    Let me know of any problems or changes needed.
    Regards,
    Frank.
    Jan 2006
    114
    Smile
    Hello Frank a.o.,
    i dident yet try this program (nex week)
    I've use the postprocessor for engraving the Micky with some changes.
    When the machine ends the programma, the machine runs with G00 to X0 Y0 Z0,
    buth the problem for me was that my machine has no homeswitchs. So i delete the last 2 rules
    and everything is OK.
    For the next month, i try other workpieces to test (and Learn) Alphacam.
    Thanks Frank, you're verry helpfull.
    Pierke
    Apr 2010
    89
    Post Update
    Hi All,
    My Apologies there was a typing error in the Metric posts, fixed now.
    Added choice by User of different Reference Home options of either
    G91 G28, G91 G28.1, G0 G53 or just G00 (for Pierke's machine without limit switches).
    Read the Edit History at top of Post.
    Regards,
    Frank.
    Apr 2010
    89
    Hi Mike,
    Here's the Post Processor with the changes you requested, let me know of any problems.
    Regards,
    Frank.
    Apr 2010
    89
    Hi Mike,
    Here are the files i'd like you to check. you should be able to just remove the .txt file extension and leave the original file extension.
    Regards,
    Frank.
    Sep 2009
    14
    Hello Franck.
    first i very apreciate your help.
    my question is : i am trying for months to figure out a way to machine elements in my horizontal machine with a disk (it is a stone machine that i have built for stone elements like sculptures, bassins, fountains etc...)
    i have tryed everything but with no results until now. i am using Alphacam and mach 3. the only way that i could find is to reverse between the "Y" and "Z" axis in the Gcode program. but i know that it is not a solution for ever.
    if someone had the same issue and fixed it i will realy apreciate to know it.
    thank's
    michel
    Apr 2010
    89
    Quote Originally Posted by michel colonade View Post
    Hello Franck.
    thank's
    michel
    Hi Michel,
    From your question I'm assuming you are machining in the G18 (X,Z) Plane, The Post you are using is more than likely only for the G17 (X,Y) Plane which is the default for standard 3-Axis machines and the default drawing Plane in Alphacam.
    The Post can be easily altered to output code for the G17, G18 and G19 Planes. I'll send PM with info where to send the Post you are using
    Regards,
    Frank.
    Sep 2009
    14
    thank you Franck. i appreciate that very much.Click image for larger version.
Page 1 of 2 12
  1. AlphaCAM post
    By KLarson in forum Shopsabre
    Last Post: 08-09-2016, 04:32 PM
  2. Post Processor - AlphaCAM
    By nologome in forum Mentors & Apprentice Locator
    Last Post: 08-14-2010, 02:33 PM
