585,978 active members*
4,333 visitors online*
    Oct 2009
    16
    Endmill grinding
    Is any one using their tormach to regrind used end mills?
    I have the 8” rotary table and a 90’ head attachment (to do the end relief). Does the tormach repeat close enough to grind the OD (flutes)? Is there a place to find all the end mill standards (helix, relief angles)?
    Mark
    Jun 2006
    3063
    This is just a personal viewpoint, but I'd be pretty reluctant to use a grinding wheel on my Tormach mill. The grinding grit goes places you don't want and way oil turns it into a passable lapping compound.
    A better option might be to pick up a good used tool & cutter grinder and set it up in your shop as far away from your precision machine tools as possible.
    Mike
  1. Router Bit or Endmill
    By cncneo1 in forum WoodWorking Topics
    Last Post: 11-27-2017, 03:00 PM
  2. endmill size
    By 15mgtar in forum PCB milling
    Last Post: 01-21-2010, 02:40 AM
  3. 5/32 endmill holder
    By Hack in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 06-01-2009, 12:24 PM
  4. Endmill design
    By ARIF AHMED in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 10-14-2008, 02:32 PM
  5. Shorten My Endmill
    By DroopyPawn in forum CNC Tooling
    Last Post: 11-13-2007, 01:05 AM
