585,908 active members*
3,780 visitors online*
    Jun 2009
    146
    distance measurement of lens from work bed
    Hello
    I am just working on some thin paper cutting and wanted to be absolutely accurate with my focus. I have a piece of acrylic 62mm square which came with the machine. I have been measuring 62 mm from the top of the plate holding the lens holder. This has been fine for most of the work I have done but for thin paper I want the beam as small as possible.
    If anyone has any advice or instruction on exactly where the 62mm should be measured from I would be grateful
    carl
    3040 laser (rabbit)
    rabbit / ls3040
    Jan 2006
    47
    Why not simply try it?
    Adjust your z-height until you get the best result, mark the distance for future use and thats all there is to it!
    Zoefie......
    Aug 2005
    108
    are u saying u use a 2.5" to cut paper? try use 1" - 1.5" , u ll get tinner spot. made a mesuarement , from lens head cone till material surface, ( u can get it and cut a acrylic and use it as FL model )
  1. DUAL FOCUS LENS (bifocal lens)
    By bibi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-12-2013, 08:56 AM
  2. 0.01 mm Tool Measurement
    By Leha_Blin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-09-2009, 06:04 AM
  3. Voltage Distance from work Ratio
    By Big John T in forum Waterjet General Topics
    Last Post: 04-21-2009, 01:53 PM
  4. I need a measurement from a Sherline CNC kit...
    By vlmarshall in forum Benchtop Machines
    Last Post: 01-29-2009, 05:10 AM
  5. Accuracy measurement
    By freddrago in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2007, 11:45 AM
