Homebuilt Plasma machine
THC300 Torch Height Control
Hypertherm Powermax 1000 Plasma with machine Torch.
Finecut Consumables used for thin sheet.
Sheetcam programming software
Is there anything I can do to improve my floating head setup.
I mainly cut 1.5mm (16swg) stainless steel with finecut consumables and I get problems with the floating head flexing the sheet too much before it trips the microswitch.
Even after the head has risen to its 2mm piercing height the nozzle is still touching the sheet and it sometimes burns the nozzle out.
Today I burned two nozzles out within 5 minutes of each other, not cheap at £6 a throw
It is fine when it pierces over a slat and the thin sheet does not flex.
I have the offset set in Sheetcam and I have had to resort to raising the offset by an extra .5mm which is not ideal.
I have seen some 'Non-contact' devices to sense the initial height, are these any good?
Any other ideas much appreciated
Andy
