585,754 active members*
3,785 visitors online*
    May 2010
    Restore dos on Grundig Numeric
    I've bought a used Masturn lathe with a Grundig Manual Plus control (earlier Phillips later Heidenhain Manual Plus), but due to battery failure the contents on the flash disk has been corrupted. When I try to start the machine, I only get "Operating system not found".
    Is there anyone who knows how to restore the dos operating system on this control? From what I've read in the manual, I think there should exist a restore disk, but no such disk followed the lathe.
    Nov 2015
    Quote Originally Posted by oyvind View Post
    Do you have a manual for "Grundig Manual Plus control" ?
    Feb 2023
    Re: Restore dos on Grundig Numeric
    Hej!
    Fick du igång maskinen?
    Jag har exakt samma problem med min Masturn cnc 50.. Köpte maskinen ikke fungerande.
    Apr 2018
    129
    Here is an English translation of the Swedish post above, via Google Translate:
    Hey!
    Did you get the machine started?
    I have exactly the same problem with my Masturn cnc 50.. Bought the machine not working.
  1. GILDEMEISTER with grundig eltropilot controller
    By russel1712 in forum Controller & Computer Solutions
    Last Post: 09-13-2023, 10:56 AM
  2. Restore Problem
    By sodfarmer in forum Autodesk
    Last Post: 04-19-2012, 12:19 AM
  3. dmg with grundig controller
    Last Post: 07-09-2010, 08:33 PM
  4. restore parameters
    By crousow in forum Fanuc
    Last Post: 03-08-2009, 10:44 PM
  5. Restore File
    By BallisticFab in forum BobCad-Cam
    Last Post: 04-24-2007, 02:27 AM
