585,978 active members*
4,464 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Anyone use router to cut 16ga Aluminum treadplate?
    Dec 2008
    19
    We tried plasma cutting a fairly involved design in 16ga aluminum treadplate and it was warping considerably.
    Was wondering if we could router it with a 1/4 HSS bit? straight flute double cut
    If you think we can, please recommend RPM and feed rate. And appropriate bit.
    thanks
    Attached Files Attached Files
    May 2003
    CNC Router would be the best way to do this. In our shop we would use a 3/16" single "O" flute bit, 22000 rpm, 80 ipm.
    Little bit of oil to keep it lubricated.
    Have fun
    Greg
    Jan 2008
    2247
    I do aluminum treadplate often with plasma, excellent cut quality, no warpage whatsoever. If you are experiencing warpage with plasma on this thickness of aluminum....you are using too much power, too large of a nozzle, cutting too slow, torch height too high....or a combination of the above!
    On 1/16" treadplate the torch height is .062", I cut with the bumps up...the automatic height control climbs over them nicely, cut speed is around 150 ipm, cut amperage is 45. Very nice clean cuts with just a small fuzzy burr on the bottom edge that rubs off easilly with your finger.
    Here are some pics of aluminum cutting wth a Hypertherm Powermax45 plasma on a PlasmaCam cnc machine:
    Jim Colt
    Attached Thumbnails Attached Thumbnails PlasmaCambuild 012.jpg   PlasmaCambuild 021.jpg   IMG_2766.jpg   IMG_2768.jpg
  1. Power Assist for Pexto 16ga x 52" sheet metal shear?
    By adbuch in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2015, 07:04 AM
  2. DIY Aluminum cnc router Frame
    By gio666 in forum News Announcements
    Last Post: 08-08-2010, 05:25 AM
  3. Cutting aluminum treadplate.
    By Orangejbird in forum Waterjet General Topics
    Last Post: 05-25-2010, 08:12 AM
  4. Problem Cutting 16ga steel PowerMax 1000
    By Peepers in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-20-2009, 04:14 PM
  5. Using a CNC Router on Aluminum
    By emarthinsen in forum DIY CNC Router Table Machines
    Last Post: 02-21-2006, 01:47 AM
