585,956 active members*
4,533 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal thru spindle coolant issues
Results 1 to 11 of 11
    Jun 2008
    11
    Hello everyone,
    I am new to this site and would like to gain some knowledge about Fadal VMC's. I have three Fadals, two 40 tapers and a 50 taper. They are all 2005 model year. I have experienced just a ton of problems with the thru spindle coolant systems that are on these machines. I have had to replace seals and belts every six months.
    Has anyone else heard of this major problem?
    Jul 2008
    7
    yes,,get rid of that
    900
    Have you considered the new pneumatic designed coolant thru the spindle? It is a vast improvement over the original one.
    Neal.
    Jun 2008
    11
    I did have all of the machines upgraded with the pneumatic system while they were still under warrenty and the problem seemed to get worse. What I found is that with the pneumatic system the seals are forced togather by air so they can run dry for a breif time if coolant is not to the seals before the spindle turns on. With the old system the seals were forced togather by the flow of the coolant thru so they could not run dry at all, but that system allowed a little bit of coolant to bypass the seals while they were coming togather.
    Thank you for your reply!
    How long do your seals last before they start to leak? Or in other words, how often do you replace the belts?
    Feb 2006
    24
    Easiest way to solve this that we found, was that when the foreman comes in in the morning (he's usually here a half hour before everyone else) he turns the machines on and runs our warm-up program for all our mills which turns on the thru coolant and lubricates all the seals. Some times the machines won't use thru tool for weeks at a time, and then the first time you turn it on it leaks everywhere. This way the seals get lubricated daily for roughly 1/2 an hour or so until the operators come in. We don't use the new air system either.
    Jul 2005
    100
    I have 2 mills with the new pressureized seal system. No problem so far.
    I have found the older style will leak if not used on a regular basis.
    Also don't let your coolant get below 8% or the lack of lube will damage
    the o-rings and rust the drawbar.
    Sep 2008
    11
    Quote Originally Posted by IN2GLAMISGIRL View Post
    why 8%? we run ours between 5%-and 7%---we have three 3 axis fadal 4020.
    Jul 2005
    100
    8% coolant
    I have found this is the ideal ratio for the coolant we use (Blaser 2000).
    Tool life and rust problems also show up at 5%. I test once each week and adjust back to 8% .
    Apr 2005
    1194
    You can say 5-7% but how much tramp oil do you think is in there?
    Apr 2009
    105
    Check out Lightning Cool. It's a retrofit done by the Fadal dealer.
    We had the same problem with our 3016HT and just installed the Lightning Cool. It cost us $4800 installed.
    Still working in the "D".
    Feb 2021
    Re: Fadal thru spindle coolant issues
    First you have to understand that the Fadal system is based on a minimum pressure of 100 psi to 200 psi, which is the maximum to keep the system working in optimal conditions, the coolant through filter must be changed every two months, if the system is not used at Daily you have to activate it every day for at least 15 to 20 minutes the coolant through so that the seals and Oring do not dry out. the pressure of the coolan is what seals the system has a graphite seal and a seramica seal these two seals are what prevent the coolant from leaking
  1. Replies: 10
    Last Post: 03-17-2015, 03:52 PM
  2. coolant corrosion issues
    By Gnome in forum MetalWork Discussion
    Last Post: 04-26-2010, 07:33 PM
  3. 1987 Fadal 4020 Spindle Coolant Tank
    By jon_fallon in forum Fadal
    Last Post: 06-14-2008, 12:53 AM
  4. New Fadal through spindle coolant by Lightning Cool
    By lightningcool in forum News Announcements
    Last Post: 05-27-2008, 06:47 PM
  5. New VF6 Thru Coolant issues
    By jybute in forum Haas Mills
    Last Post: 11-15-2006, 06:16 PM
