Hi. I'm running a script to make a thread by helical interpolation (so it is a bit taxing to the X and Y motors I guess?), and each time all 3 motors seize up part-way and start spazzing out (they don't seem to undergo any net movement, but they start randomly pulsing). I've tried this 3 times and each time this happens about halfway through the script.
So here's what I'm running/the list of candidates for what's messing up:
Mill: X3 with CNCFusion CNC conversion
Steppers: Keling NEMA23 on each axis (KL23H286-20-8B)
Power Supply: Keling KL-320-36 36V/8.8A
Motor control: Geckodrive G540
Software: Mach3 on WindowsXP
At first I thought one of the motors might be overheating because they were getting pretty hot, but after clamping some heatsinking to them I still had the same problem.
All 3 motors seem to lock up simultaneously. Even when I stop the program or try MDI control they don't respond and just keep spazzing. After a few tens of seconds of this the Gecko G540 finally throws a fault and the motors stop.
Given that all motors seize, I'm guessing the problem is the Gecko G540?
Has anyone experienced anything like this? Anyone have any recommendations/diagnostics/advice? Thank you for your help!
