585,880 active members*
9,230 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Sanyo PY0/PY2 Tuning Software
Page 3 of 3 123
Results 41 to 49 of 49
  1. #41
    Sep 2010
    26
    Re: Sanyo PY0/PY2 Tuning Software
    Does anyone have a serial cable PIN diagram?
    Thank
  2. #42
    Jul 2020
    You can find the software manual here, and on page 41 is the cable PIN diagram: https://manualzz.com/doc/26762500/us...---sanyo-denki
  3. #43
    Sep 2010
    26
    Quote Originally Posted by luisvidigal View Post
    Thank you.
    Maybe you have a diagram of encoder cable (PY2 - P5 motors)?
  4. #44
    Jul 2020
    Quote Originally Posted by darkoford View Post
    Thank you.
    Not sure if this is what you need but check this out. Did you manage to connect with the driver with the software? I am still trying to connect with the driver. Spent the hole day today but no luck. I have the software installed in a virtual machine winXP 32, do you know if is possible to communicate with the driver while using the virtual machine, or I need a PC running native winXP? regards
  5. #45
    Sep 2010
    26
    I need the correct wire layout for encoder PY2 -> P5. so I can test the correctness because it shows me the encoder error flashing "8".
    The machine on which the equipment was used was WIN NT 2000.
    I haven't connected the amplifier to the PC yet because I don't have a connector. Maybe connect directly in the coming days.
    Btw. Unable to open file (last). If you can email [email protected] Thanks
    Attached Thumbnails Attached Thumbnails Screen Shot 07-24-20 at 04.53 PM.PNG
  6. #46
    May 2022
    Quote Originally Posted by heathmanc View Post
    I've had a couple people ask for this software, so I've decided to attach it here.
    Charles
    hi charles i tried to install this software on w10 but i have a trouble trying to install it on my PC, i have a message that told me is not a version for my computer, i tried disable the smartscreen and install with compatibility of WXP SP3 but i got always the same truoble, some idea for solution this problem?
    thanks.
  7. #47
    hy sir can you send me the connection diagram of this cable or connection image
    i shall be thankful to you
  8. #48
    Dec 2022
    Charles
    I have an issue running the setup. "This app can't run on your pc"
  9. #49
    May 2023
    Precisó este software
Page 3 of 3 123
  1. Fanuc servo tuning software.
    By GPena in forum Fanuc
    Last Post: 03-16-2019, 02:14 AM
  2. Sanyo-Denki BL Super BL827 amp, 27BA030FXT tuning
    By bevins in forum Servo Motors / Drives
    Last Post: 02-21-2014, 02:49 PM
  3. Best servo drive with tuning software for my DC servos?
    By RouteBot in forum Servo Motors / Drives
    Last Post: 09-22-2013, 09:08 PM
  4. R2010 Tuning Software
    By foxprints in forum Servo Drives
    Last Post: 01-03-2007, 03:05 AM
