585,933 active members*
3,754 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 750 with CT control error message 9036
Results 1 to 7 of 7
    Dec 2008
    6
    I have a 1994 Arrow 750 with the CT control. I'm getting a 9036 error message "Static RAM File System Corrupted Main PLC". Does anybody have any ideas on how to fix this? Any help would be appreciated.
    Dean
    218.590.3130
    Jan 2008
    48
    It could be a goofy program so purge them all. If that does not fix it you will need to reload all the software. I have had that message 2 or 3 times.
    Dec 2009
    Hi
    I have the same problem in the 1995 ARROW 500 which we just bought.
    In addition to the error message, there is another one.
    "Static RAM FIle system Corrupted COMP PLC"
    9253 PLC name definition error _9.13 "09.13"
    File: Main.plc
    SOurce line number : 463
    _9.13 "09.13"
    I don't know where to find the file.
    Also, it seems the memory board is missing.
    I suspected the backup battery is dead too.
    Is there suppose a floppy drive in the machine? WHere?
    Is there a hard drive?
    Thanks for help in advance.
    Jul 2007
    62
    Have you guys fix your machines yet ? I think I can help you.
    Aug 2014
    12
    Re: Arrow 750 with CT control error message 9036
    I also have the same problem u.u do you know what can be done in this case??? I am desperate :violin:
    I bought this machine hoping to run my machine shop, please help
    Aug 2014
    12
    Btw, the machine is from 1994
    Jan 2018
    Error9036 : Sistema de arquivos RAM estático corrompido
    MAIN.PLC
    FNC.LM1
    Error9245 : Número de bits do PLC fora do intervalo (!)
    AndnGammaP Id B31.02 'Mudança de marcha do Terugkoppelen
    Arquivo:
    main.plc Número de sourceline: 1502
    andnGammaP id B31.02 'Mudança de marcha Terugkoppelen
    Tenho o mesmo problema, alguma ideia para uma solução?
  1. Cincinnati Arrow error 9036 HELP!
    By cncwork in forum Cincinnati CNC
    Last Post: 01-09-2023, 12:06 AM
  2. Replies: 0
    Last Post: 11-25-2013, 02:13 PM
  3. DX-32 Control, Error Message, No Clue!
    By minton in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-30-2011, 04:34 AM
  4. Cincinnati Milacron Arrow 750 Error Message
    By Nikon Phil in forum CNC Machining Centers
    Last Post: 02-11-2011, 12:08 PM
  5. GE control error message
    By Good_GuyMN in forum DNC Problems and Solutions
    Last Post: 02-14-2009, 08:22 AM
