585,744 active members*
4,682 visitors online*
Thread: Citizen M32
Results 1 to 6 of 6
    May 2010
    Citizen M32
    recieving ex509 alarm, clutch not properly engaged. i have followed the steps in the manual but still cannot get the turret to comlete a tool change.
    Apr 2010
    Have you zero returned the turret?
    May 2010
    quite simple really you have to do is remove the turret cover find and adjust the clutch location to the cam then adjust the proxy sensors for the clutch and rack and finally re teach the turret its location in the parameter screen
    304
    NO NO NO NO!!!
    Call Citizen and they will send you a proceedure to reference the turret and it will be fine. No manual adjustments, just a step by step method will solve it for you.
    Aug 2011
    Re: Citizen M32
    Quote Originally Posted by Microtek Swiss View Post
    just push preparation function and then select retract turret..start
    Nov 2014
    26
    Re: Citizen M32
    cogsman
    You are correct do not adjust the switches
    If the procedure from Citizen will not work the span ring on the last gear has moved
  1. NEWBIE to Citizen - G32 thread whirling on Citizen L520???
    By jmonty in forum CNC Swiss Screw Machines
    Last Post: 09-07-2013, 06:50 PM
  2. Citizen A16
    By bpalmer in forum CNC Swiss Screw Machines
    Last Post: 09-15-2012, 12:57 PM
  3. Citizen L25
    By sonny68 in forum CNC Swiss Screw Machines
    Last Post: 08-01-2012, 04:44 AM
  4. Citizen L20
    By humbertocnc2007 in forum CNC Swiss Screw Machines
    Last Post: 06-19-2012, 01:31 AM
  5. G12.1 + G16 on Citizen C16
    By Koalas in forum CNC Swiss Screw Machines
    Last Post: 09-04-2011, 05:36 AM
