Suggestions on clearing "DSP Fault - DSP interup failed" I'm the office guy trying to help the machinist. Thank you.
Make sure the estop button isnt depressed, hit clear on control. If possible jog one axis at a time and see which one causes it. This error means that there was a connection lost some where in the system. this system is in a loop. i would check the cables coming from the motors for kinks or tears in the cords. possible a connector is loose? if not one of the motors are bad. cables are part of the motor. I would also try moving the axis's and see if the dro display changes as you manually move that axis.... hope that helps!!
