585,764 active members*
4,440 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Dual Steppers or Timing Belt for Dual X-axis?
    Jan 2010
    44
    In my project I need two lead/ball screws to drive the X-axis.
    I can connect the two with a timing belt and use a single stepper motor or I can use two stepper motors slaved together.
    I'm new to all this, so my question basically boils down to "How hard is it to get 2 stepper motors to run identically?"
    My setup is a HobbyCNC Pro 4-axis board and 305 oz/in stepper motors. Mach3 software.
    Thanks!
    Gary
    Running two motors that way is no problem. What you have to consider what will happen if one motor stalls and the other keeps on trucking. Consider a belt between screws if that situation can damage the mechanism.
    Mariss
    In Mach3, go to Config>Slaving and check a box. That's it.
    The majority of medium to large routers built by members here use slaving in mach3.
    Jan 2010
    44
    Thanks for the replies guys.
    Given that damage could occur, and the low mass that I'm trying to move, I'm going to go with direct driving one screw and a timing belt between the two.
    Helpful folks here as always.
    Gary
  1. Dual Z axis and Dual Spindle
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 08-28-2008, 09:15 PM
  2. Do I need mechancial synchronizing dual belt drive?
    By kiwibum in forum DIY CNC Router Table Machines
    Last Post: 05-19-2008, 04:18 AM
  3. Dual Lead Screw W/ Indipendant Steppers
    By CAMCRASH in forum Linear and Rotary Motion
    Last Post: 12-18-2007, 02:48 PM
  4. Question - Dual Steppers
    By Limedodge73 in forum Stepper Motors / Drives
    Last Post: 12-07-2007, 05:36 PM
  5. Dual Lead Screw W/ Indipendant Steppers
    By CAMCRASH in forum Stepper Motors / Drives
    Last Post: 08-06-2007, 02:35 AM
