Someone have the maintenance manual for these CNC? with the control OSP-P200
I work for a new project and I search the output and imput of the control.
like the picture of OSP-e100 etc.
thanks
thanks
Think i have it. What exactly do you need?
Do you have the PDF of the maintenace manual of a okuma LU300 of a LT200?
We bought these two CNC but we will receve IT in one mounth and I need this manual
to make parametric programming, verify output, imput of the control OSP-P200
, robot, plc etc..
Habitually the CD IT comes with the cnc.
I have an LT200MY with P200, so the file is available to me - however, the E-100 and the P100-200 are laid out electrically the same, so the I/O is the same as well. Do you still need the manual if this is the case? or will yours do just fine for you?
Best regards,
Oh, I just found it...but it seems to be having trouble uploading..do you have an e-mail you could send?
"We bought these two CNC but we will receve IT in one mounth and I need this manual"
you should have the paper manual and the cd with all the pdfs. If you have not taken possesion of the machine, the dist should provide it.
Because we will recieve these CNC in around 6 weeks in a plant on Oklahoma, USA and I am in Canada....
It's a big project with robots, gaging system etc.. I work for parametric programs and the programs must be finish in 6 weeks also.... a lot of stress....
I know i will have this document with the CNC but in 6 weeks it's to late for me.
Thanks to help me.
I understand, You need map of outputs, inputs of Your machines for automation project. I mean, general manual doesn't fits. You need the documentation of Your machines.
Okuma can send requested pdf's instantly by e-mail. Even if You will wait for CD, it takes just about a week.
Hallo
Do you have receive the pdf's?
It's possible to get a copy off it?
<div align='center'><strike><b><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo-->!!!!....JA....WIR....LERNEN....NI E....AUS....!!!!<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--></b></strike></div>
