586,005 active members*
5,034 visitors online*
Thread: PCB milling
Results 1 to 6 of 6
    May 2005
    4
    PCB milling
    Hi to everyone!
    This is my first post here, and honestly I don't know if this is the right section... (excuse me for now that. For now I'm a bit confused with this big place!).
    My question is simple:
    From some months I'm engaged to build a small cnc milling machine to realize my PCB hobby projects.
    Over the net I find some ideas about mechanics and control electronics.
    By the time, I'm searching some software solution to control the system, but here comes some trouble:
    I use "eagle" to create my electronic projects... this application has got a CAM processor with Gerber, HPGL, Excellon, ecc. output.
    But when I import this output to some CAM soft, like Kcam, it is not well reproduced.
    Can anyone has some experience (and than some ideas) to realize:
    PCB track "de-contour" or some right transformations?
    Well export-import drill file (for holes for "Trought Hole Technology")
    Some tested procedure for doing that?
    Thanks a lot and excuse my bad english!
    Fabrizio
    Apr 2003
    361
    Fabrizio,
    No need to use the CAM, just download the ULP (GCode.zip) from link below and run it. So far no problem with KCam.
    http://www.cadsoft.de/cgi-bin/downlo.../userfiles/ulp
    Inside the .zip there are 4 files: for PCB outline, PCB track normal, PCB track mirror image & for drilling gcodes. Have fun...
    Stupid questions make me smarter...
    See how smart I've become at www.9w2bsr.com ;-P
    May 2005
    4
    Thanks, man
    this seems very helpful!!
    I will try this ulp ASAP...
    Apr 2003
    372
    FabCNC,
    DeskCNC is the best I've Found So Far.
    "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
    Greetings From Down Under
    Dave Drain
    Akela Australia Pty. Ltd.
    May 2005
    4
    G-code.ulp Works great with OUTLINES in Kcam!!
    But have some problems with drill g-code...
    I never try DesKam... I will search for it and try...
    Thanks for now!
    Fab
    Apr 2003
    361
    Quote Originally Posted by FabCNC
    But have some problems with drill g-code...Fab
    What's the problem :devious:
    The GCode produced uses G82 (Drill & Dwell). IIRC, KCam supports the G82 so shouldn't be any issues.
  1. Spindle speeds for PCB milling
    By CactusChip in forum Uncategorised MetalWorking Machines
    Last Post: 04-20-2007, 09:54 PM
  2. Having trouble cutting aluminum sheet
    By fastturbovet in forum MetalWork Discussion
    Last Post: 06-15-2005, 04:33 AM
  3. pcb milling
    By dberndt in forum Employment Opportunity
    Last Post: 01-03-2005, 03:44 PM
  4. Where to buy CHEAP PCB milling bits
    By abasir in forum CNC Machine Related Electronics
    Last Post: 04-18-2004, 03:14 AM
  5. Cutting tool shape for PCB milling
    By NeoMiller in forum Uncategorised MetalWorking Machines
    Last Post: 11-13-2003, 06:09 PM
