585,987 active members*
4,559 visitors online*
    Nov 2009
    105
    Adding Homes??????
    Greetings, I am adding home and limit switches to a Zenbot and I am using Kcam. Should the switches be normally open or closed? Thanks in advance for any help received.
    4826
    Select a method which is most foolproof. If a wire breaks on this circuit, will the machine know the difference between the normal and the abnormal condition? And do you care if it knows?
  1. Earth Sheltered or Earth Bermed homes
    By Edwardo in forum Environmental / Alternate Energy
    Last Post: 07-12-2012, 11:01 AM
  2. x,y,z,a homes switches
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 02-22-2009, 07:41 AM
  3. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
  4. Replies: 9
    Last Post: 03-22-2008, 05:44 AM
  5. New Homes For Geckos
    By mlaws1172 in forum CNC Machine Related Electronics
    Last Post: 02-23-2006, 09:29 PM
