585,581 active members*
3,967 visitors online*
    Mar 2007
    17
    TNC 145 - Electronic Part Identification
    Hey all,
    I'm currently dismatling my TNC145 controller and trying to identify an electronic part. Basically it's mounted on the first board on the top right hand corner. It resembles a fuse in size and shape but has a red graduated scale along it's body, going from zero to ten. Does anyone know what this is ? Haven't seen one before.
    I'm currently drawing out a circuit diagram for the board, until I find the fault - Heidenhain only seem to make the block diagrams available - no schematics about ?
    Joe
    Apr 2009
    24
    Hi Jo
    I would be greatfull of your diagrams when you are done. I am trying to trace a power supply board problem but like you am having trouble getting info on the circuits.
    Cheers and good luck.
    Mar 2004
    369
    Quote Originally Posted by Joe_Leen View Post
    Hey all,
    Joe
    I suspect it is a running time meter. They have a glass tube with some electrolyte and mercury in it, and a small current causes the mercury to move from one end to the other of the tube. It will have a resistor in series with it, and be connected across a power supply. If you reverse it, the line will start moving the opposite direction.
    Jon
    Aug 2010
    109
    Jon is correct it is a run time counter for the display. Tektronix also uses those on the o-scopes and spectrum analyzers for service purposes.
  1. CNC identification
    By 777string in forum Benchtop Machines
    Last Post: 01-30-2010, 02:54 PM
  2. Bridgeport identification
    By unlock in forum Bridgeport / Hardinge Mills
    Last Post: 11-06-2009, 06:11 PM
  3. Ballscrew identification
    By TowerCNC in forum Linear and Rotary Motion
    Last Post: 08-20-2009, 10:37 PM
  4. Lathe bit identification
    By jimmy205 in forum Uncategorised MetalWorking Machines
    Last Post: 04-03-2008, 05:01 PM
  5. Stepmotor Identification
    By Kresimir in forum Stepper Motors / Drives
    Last Post: 02-01-2007, 07:14 PM
