585,981 active members*
4,266 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Jan 2006
    104
    hello yssvaff,
    When I started the robofil 200 this morning I pressed the monitor key. The machine displays the following " E05 P07? " All the keys on the cabinet are not functioning. I switched of the machine but on starting the same screen is coming. Please help. How to come out of this loop?
    "E05 P07" usually means a bad power supply.
    check for green led's on the UA/SAL circuit board. (no red leds lit just after power up.)
    check your 24 vdc power supply.
    check the NC rack power supply above the monitor for 5 vdc, plus/minus 12vdc (or 15vdc)
    good luck,
    michael
    Registered Linux User #348337
    EMC2 Rocks!!!!
  2. #22
    Dec 2009
    18
    will Robofil 200 serve my purpose...
    Quote Originally Posted by Shawn Lucas View Post
    Don't expect this machine to be fast by today's standards. It will do a good job everyday. I have come to enjoy and admire the simplicity of operation of this machine, while also using some of the more advanced features. For example the twist feature for making a twisted shape through a part saved me considerable time and money by not requiring a 4 axis program to be written. We have also found the machine to be a capable 4 axis machine. There are a few things annoying also. The machine was really designed around the use of stratified wire, this is a bit more expensive to purchase. Also the battery backup system works great, but not for very long.
    Hi Shawn,
    we are a toolmaking company engaged in design & mfg. of precision stamping tools , & stamped parts. we have a sodick A320D AWT , in good working condition , however is not able to hold close tolerances & no corner control , hence we have to outsource precision work , we need an accuracy of 3-5 microns, good corner control , good finish & a reliable & honest m/c. Speed is not my concern.
    can Robofil 200 serve my purpose ?
    Atul
    [email protected]
  3. #23
    Sep 2012
    15
    Hi everybody
    The machine has started. Did a small job, a square, in 3 cuts. But I don't have a wire tension meter so the tension could not be exactly adjusted. So the finish was not that good.
    The next day gave a CTR command for a straight cut. But it is alwags giving erron E660 or E648 But the wire is not broken. Is there some kind of wire breakage sensor somewhere. For E660, wherre is fuse on PCB APMF. There is no fault in anti-diagnostic testing.
    yssvaff
  4. #24
    Jan 2013
    9
    I am new here i have problem, i cut the measure that is tolerated 9.97 mm my teh is E3,H45 but in finish cut mesure is 9.91 mm. I then input E4,H45 but now is mesure 10 mm. What is problem? Robofil 200 please help.
  5. #25
    Sep 2012
    15
    Hello mdynac
    The problem that I had mentioned went away when I changed the batteries. But now the machine has stopped functioning. The machine was showing the power supply error which I neglected. The power supply is out. It is Wier NT200. Do u have by any chance the schematic diagram of the power supply. This PS is quite old design with obsolute components. Help will be appreciated.
    yssvaff
  6. #26
    Jan 2006
    104
    Quote Originally Posted by yssvaff View Post
    Hello mdynac
    yssvaff
    no i don't have any schematics for the weir.
    for a replacement, use:
    5 Volts DC at 60 amps
    plus/minus 12vdc or 15vdc at live 5 amps each should do.
    good luck
    mac
    EMC2 Rocks!!!!
  7. #27
    Dec 2018
    Re: Charmilles Robofil 200 operating process
    Hi, Im having the problem right now with my Robofil 290, can you tell me how did you fixed it?
Page 2 of 2 12
  1. CHARMILLES ROBOFIL ALARM/MANUAL
    By SINUMERIKO in forum Waterjet General Topics
    Last Post: 10-13-2023, 08:18 AM
  2. Charmilles Robofil 200 startup
    By Shawn Lucas in forum EDM Discussion General Topics
    Last Post: 07-23-2021, 12:20 PM
  3. Charmilles Robofil Wire Edm
    By sundara in forum EDM Discussion General Topics
    Last Post: 08-01-2017, 09:56 PM
  4. Charmilles Robofil 440 Power Settings?
    By Tool Maker 24 in forum EDM Discussion General Topics
    Last Post: 09-10-2009, 10:50 AM
  5. Charmilles Robofil 300/310 Door Alarm
    By WIRE CUTTER in forum EDM Discussion General Topics
    Last Post: 07-26-2009, 12:34 AM
