hello yssvaff,
When I started the robofil 200 this morning I pressed the monitor key. The machine displays the following " E05 P07? " All the keys on the cabinet are not functioning. I switched of the machine but on starting the same screen is coming. Please help. How to come out of this loop?
"E05 P07" usually means a bad power supply.
check for green led's on the UA/SAL circuit board. (no red leds lit just after power up.)
check your 24 vdc power supply.
check the NC rack power supply above the monitor for 5 vdc, plus/minus 12vdc (or 15vdc)
good luck,
michael
Registered Linux User #348337
EMC2 Rocks!!!!
