585,578 active members*
3,893 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Change a motor from 415v 3 phase to 220v 3 phase
    Apr 2004
    105
    I don’t know how I will go here but hopefully someone may have an answer. I have a good quality bench grinder specs are 1 HP, 415V 3 phase, 2800 RPM, 1.5 Amps.
    Can this unit be run directly off 220V 3 phase without damaging it?
    If not can it be converted from 415V to 220V, noting that there are only 3 wires coming out of the motor casing, if it can only be run at 415V in this configuration is it possible to make a change internally to allow rewiring to 220V? If so I would pass it to specialist motor rewinder to do this.
    Cam
    24220
    Normally dual voltage motors have at least 3 pairs of wires coming off the motor, if dual voltage Star, then there would be a 9 wires.
    If you only have 3 then I would suspect it has been wound for uniquely 415v.
    If so opening it up would be no advantage.
    Al.
    Albert E.
    Apr 2004
    105
    Thanks for your reply Al, the other question, can it be run at the 230V 3 phase without damaging it?
    Regards
    Cam
    24220
    Not something I would recommend, the current induced into the rotor is going to be proportionately less this will lead to reduced torque, greater slip (rpm), etc, and will not take to load lightly.
    If you try it, monitor the phase currents while you do.
    I suspect the performance will be less than stellar.
    Al.
    Albert E.
  1. Can I convert single phase motor to three phase?
    By Jim Estes in forum Phase Converters
    Last Post: 06-04-2020, 02:52 PM
  2. Convert three phase transformer to single phase?
    By jimjovan in forum CNC Machine Related Electronics
    Last Post: 09-16-2013, 11:32 PM
  3. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
  4. CONVERT SINGLE 240/480V POWER TO THREE PHASE 415V OUTPUT
    By PhaseChangeConv in forum News Announcements
    Last Post: 09-03-2008, 05:45 AM
  5. 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ...
    By kochevnik in forum Stepper Motors / Drives
    Last Post: 10-23-2006, 04:48 AM
