585,978 active members*
4,508 visitors online*
    May 2010
    Question Sign Foam Board
    I've been making signs for a few years now, and I'm in the process of building my first CNC machine. I'm hoping it'll be done in a week or two, which brings me to this question.
    Is there sign foam board sold that has a colored outer core and a white inner core? I have a gig to make signs for a golf course, nothing fancy, but they want green and white signs. I'm thinking this would be a huge time saver if I used a v carved look. No painting.... tada! :banana:
    Has anyone ever worked or found something like this? Any help would be appreciated.
    Thanks.
    Sep 2006
    28
    Wouldn't you be much better off buying a vinyl cutter and just apply green cut vinyl to white PVC foamboard?
    Jun 2009
    20
    Quote Originally Posted by KnotsAboutWood View Post
    Thanks.
    Paint the board the color you want first, then use a vinyl film to cover it. Then cut. Then paint the revealed core in the core color you want, then peel back the vinyl to reveal the surface color again. The vinyl is cut at the same time as the sign, and acts as a mask for the second coat.
    Jun 2015
    Re: Sign Foam Board
    Found this on youtube a little while ago. Great Video!
    https://youtu.be/p3lY1N4XQwY
  1. Replies: 2
    Last Post: 03-12-2013, 04:23 PM
  2. 50pt sign board
    By bradyfb in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 02-27-2012, 11:14 AM
  3. How to coat a foam sign
    By SigUser in forum Signmaking Topics
    Last Post: 05-28-2011, 03:58 AM
  4. Sign Foam 3
    By cwells in forum Want To Buy...Need help!
    Last Post: 02-14-2008, 01:51 AM
