585,982 active members*
4,521 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC 4020 monitor blowing fuse
Results 1 to 9 of 9
    Jun 2010
    We have a VMC4020 and the monitor is blowing the fuse for the 120v input
    I removed a monitor from a working machine and it blew the fuse about 2 hours later s@#&
    I repaired the old monitor and installed it in the machine I removed the replacement from and it works.
    I repaired the fuse on the monitor in the troublesome machine and attached it an external 120v source the fuse does not blow
    I monitored the power supply with an oscilloscope but nothing was observed
    any clues?
    Regards
    Matt
    Sep 2009
    181
    What year is the machine?
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
    Jun 2010
    Quote Originally Posted by iess525 View Post
    1998
    Sep 2009
    181
    It sounds like there is a short somewhere.
    Mar 2010
    Monitor fuses
    Has the monitor been working in the past? Sounds like you might have some high voltage, 220-440 shorted onto the monitor power.
    Mar 2010
    fuse
    Is it blowing the fuse in the back cabinet by the control cards that feeds the pendant or just the one on the monitor?I would track the wires back to the dist. board behind the switches and check the power for shorts and voltage,also look for any burned up components on that board i have replaced several of these dist. boards in the past with the same type of issues.the wires go to the board at j12 pins 1+2.
    Jun 2010
    As I said...
    The fuse on the monitor itself is blowing.
    I removed a monitor from a working machine and installed it in the nonworking machine and the fuse in the monitor from the working machine blew after about 2 hours.
    To get production going I connected the monitor to an external 120v power source until I can have the machine. It has been running for 2 days as of now.
    I had a recording device connected to the power source for the monitor connected to the wires (molex connector) in the machine and noted no anomalies
    I did ask the operator what sequence of events lead to the monitor going dark. In both cases the machine was just running in auto and the operator was involved in other tasks. No switches etc where pushed turned etc on the control panel.
    Mar 2010
    monitor
    The system is fairly basic the 120vac comes out of the transformer,to the 1100-1 power dist. board(by the amps),then out through the pendant fuse through the top track and into the power dist.board in the pendant if there are no shorts in that part of the system i would swap the pendant power dist. board with another machine.9 times out of 10 when i am called in on an issue like this that board is the issue.issues can be intermittent sometimes and everything looks good but when put under load it will act up.i do see the beacon light is also on the j12 plug there may be an issue there.i have also seen components on other plugs on the board cause issues on another.it all depends were the issue is and what sequence of events cause the problem.you can get the wiring manual from fadalcnc.com and download it.
    Jun 2010
    Quote Originally Posted by alex gitzel View Post
    The system is fairly basic the 120vac...
    Yeah basic as it gets
    This was the recommendation of our new hire of 2 days
    Thanks for your sage advice... We'll redouble our efforts !
    This is my first experience with any real trouble with a Fadal...
    It seems the wiring is a weak point with these machines
    Cheers
    Matt
  1. Bridgeport R2E4 blowing fuse #16
    By synergymc in forum Bridgeport / Hardinge Mills
    Last Post: 08-29-2009, 12:18 AM
  2. blowing ifc dps fuse
    By robthomas in forum Bridgeport / Hardinge Mills
    Last Post: 09-08-2007, 01:20 AM
  3. Mechatronics controller blowing fuse!
    By WilkBoy in forum Stepper Motors / Drives
    Last Post: 06-25-2007, 03:43 AM
  4. Fuse Blowing! Please Help
    By audioandy1762 in forum Gecko Drives
    Last Post: 01-22-2007, 10:52 PM
  5. Fuse blowing at start-up
    By emergent in forum Daewoo/Doosan
    Last Post: 03-22-2006, 07:42 PM
