585,981 active members*
4,326 visitors online*
Thread: Haas HRT210
Results 1 to 7 of 7
    Mar 2007
    114
    Haas HRT210
    Does anyone have a pdf (or a link) for a manual for the brushed type HRT210 table. I can only find the later models on the Haas site
    Nov 2007
    1702
    What kind of manual? For the controller? I don't think there is any difference between them except the cable and the type of motor.
    Greg
    Mar 2007
    114
    Im looking for info on the rotary unit, I wont be using a seperate controller as my machine has all the 4th axis drives
    Nov 2007
    1702
    OK, again, what do you want to know about it? Everything they tell you about it is in the current manual. It's big. It's heavy. It's made of cast iron. The platter goes 'round and 'round. Programming it on the machine is identical to the current model. The dimensions are identical. What information are you needing?
    Greg
    Mar 2007
    114
    Well the one I have been looking at has a casing on the rear of the main body which has a lever on it which moves up and down. I cant find anything that looks like this in any version of the rotary manuals. Also some info on the cabling would be good and the functions on each pin of the 17 pin connector on the cabinet. The previous owner of my vf2 had some sort of problem and damaged the servo drive board. I am trying to get everything back working again and am being cautious before I trash another drive board, so I want to check out as much as I can before I power up
    Nov 2007
    1702
    The pin-outs aren't in any of the manuals. That's probably service manual information only. We can scratch that off the list.
    The lever thing sounds like the Haas accessory collet closer or the mini-tombstone accessory. Look at the Haas website and poke around in the rotary accessories. I think you'll find the stuff you're looking for, though all of that is also in the current rotary manual.
    Greg
    Mar 2010
    1852
    Perhaps these will help.
    Mike
    Attached Files Attached Files
  1. HAAS HRT210 wiring diagram
    By jcassidy in forum Haas Visual Quick Code
    Last Post: 03-11-2010, 09:34 AM
  2. Installing / Removing HAAS HRT210 4th AXIS
    By glenn105 in forum Haas Mills
    Last Post: 01-21-2010, 07:49 PM
  3. Haas VF with HRT210 indexer, M21
    By Talisman in forum Haas Mills
    Last Post: 10-23-2009, 04:02 AM
  4. Zeroing a HRT210 Table
    By gmh265 in forum Haas Mills
    Last Post: 08-12-2008, 11:24 PM
  5. SCO2-ACR and HRT210
    By TheGreenMachine in forum Haas Mills
    Last Post: 04-26-2008, 04:23 PM
