Hi Chille,
Have you pressed the "Origin" button to set all your axis to zero. It looks as if the Z height isn't set to zero and the table is driving up to start the job at the required 0,0,0 start point.
try that and see how you go.
Incidentally, when you press the Origin button at a certain location that is the point where the laser head will return to after a Home or Reset.
Lets get you sorted out and cutting stuff and make you a bit happier. :-)
There is much frustration to be had when you first start out and it just takes a little while to get up to speed. Experiment with things and read the manual if you can't get something to work or just come here if you need to.
Rich
I am not completely useless.......I can always serve as a BAD example.
