I have two of these right now KL23H286-20-8B and a Gecko 203V coming to my place sometime. What kind of power supply should I have running these? I will eventually get a third motor but right now I am just experimenting.
Switching power supplies seem a lot cheaper, but can they cause problems? A simple unregulated one looks like it might work, something from AnTek perhaps. I am pretty sure I need at last 10 amps to run 3 axis with it, or do I need more maybe?
I have no idea about voltage. I have seen things about how you take 20 * V rating of the motor, but in the spec sheet there are several voltages ranging from 4.17 to 8.4... which would come out to a power supply capable of 80 to 168 volts? That seems excessive, and probably wrong. I would just like to get the best speed/performance out of the motors.
