Hi all,
Now that you helped me get the machine running, I've been going through the program manuals and making moves. I can't seem to make a G01 move in X & Z axis , like a 45 deg cut. It will traverse simultaniously in G00. For example: Going from memory here on the program I have been editing
G00 X10 Z12 G95 G96 T00 S1000 F0.003; START POSITON
T0100;TOOL SELECT
X6 Z6 T0101; RAPID WITH OFFSET
G01 Z5; CUT IN Z DIRECTION @ Feed
X6.5 Z6.5; CUT A 45 DEG CHAMFER. The tool only moves in the Z direction.
Is this common, am I doing somthing wrong (working off my limited mill programming) or are non linear moves all done with G codes?
I am also looking for the location of the Tool data and offset info. Right now I call up a tool and make a hopefully safe move and take some measurements.
HMC
