585,560 active members*
3,383 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > General Dyna Mechtronics info
Results 1 to 15 of 15
    Oct 2005
    672
    Since there is now a forum for Dyna Mechtronics, I figured it might be helpful to provide some general info about the company and machines.
    The company's formal name is Dyna Mechtronics. They often put a name plate on the machines that stated DYNA MYTE. Dyna Mechtronics has nothing to do with Dynapath, DynaCNC, DynaTorch, or other "Dyna"s. Their website is http://www.dynamechtronics.com/ and they are still in business.
    SKIP control machines. SKIP is Single Key Input Programming. Pretty slick in the '80s, very limited by today's standards. The SKIP control can hold about 999 lines of Dyna's proprietary conversational code. If the program is longer than that, it will have to be drip fed/DNC'd to the control. Dyna used to sell software called Dynacom for communicating between the control and a PC. I do not know if it is still available from Dyna. I think it is possible to drip feed from other software, but I have no experience with this. All SKIP machines use stepper motors for the axes. The weakest areas of these machines are the circuit boards and wiring.
    Benchtop mills with SKIP control:
    2000
    2100
    2200
    2300
    2400
    2800
    2900 (2800 with ATC)
    Benchtop lathe with SKIP control:
    3000
    Full size with SKIP control:
    4000
    4400 (same as 4000 but with ATC)
    Full size with Mitsubishi M3 & M520 controls. Dyna started moving into the bigger machine market in the late '80s with the SKIP 4000/4400 but recognized the SKIP control was a big handicap. They started using Mitsubishi M3 controls which were much more powerful than the SKIP controls and allowed for rigid tapping and much faster feed rates and rapids. Mitsubishi also used servos which were faster, more accurate, and more powerful than the steppers. Mitsubishi still supports and services the Mits components. The most common failure on the Mitsubishi is battery failure resulting in loss of parameters.
    DM4400M (same mechanicals as 4400 but with Mitsubishi M3 control)
    DM4500
    DM4800
    DM4800C (re-badged Johnford mill with swing arm ATC)
    DL3300 lathe
    PC3 controls running 4M software. In the mid-'90s, Dyna started working on their own PC based control to replace the Mitsubishi. The first handful of machines built used an industrial 486 based PC with a monchrome LCD display. Shortly after introducing the PC3 control, Dyna switched to a Pentium CPU with conventional PC mainboard, 16MB RAM, off-the-shelf hard drive, and 3.5" floppy drive. All machines ran MS-DOS 6.x with some of the later machines offering limited ethernet.
    Benchtop with Dyna's PC control:
    DM1007
    Knee Mill with Dyna's PC control:
    EM3116
    Full size with Dyna's PC control:
    DM2016
    HF3016
    DM3220
    HF4020
    DM4322
    Jun 2010
    45
    I have a DM2900 with ATC and the PC control. Looks just like the 1007, but the machine is red and the enclosure is off white. I think it may have been an early version of the 1007.
    Roger
    Oct 2005
    672
    Yes, there were a few made under that model. Dyna changed the models to reflect the travels of the machines when they switched to the PC control. Thus, the 2900 got renamed to 1007 (10" X and 7" Y). Is the display monochrome or color?
    Jun 2010
    45
    It had a pendant control, with a 486 pc with a color monitor. I moved it over to a pentium 2 computer myself.
    Roger
    Hey Caprirs,
    I think we "spoke" here once a long while ago about the Dyna Mechtronics machines. You worked for them at one point if I remember correctly?
    I have the 3000H model lathe retrofitted with an Ahha controller.
    I was wondering could you tell me what the differences are between the 3000 and 3000H models? Other than one being desktop and the other being a standalone machine. I've seen a 3000 in person, but it's been a while. I remember the 3000 being smaller than mine, but perhaps it just seemed that way and the work envelope is similar?
    If I remember correctly, the 3000 used leadscrews whereas the 3000H has ballscrews.
    Thanks for any info you can share,
    Dave
    Oct 2005
    672
    Quote Originally Posted by CNCinCal View Post
    Roger
    Dyna replaced several of the early 486 PCs. If I recall, they were called Winsys or similar. The OS was burned to an eprom. Did you keep it running MS-DOS?
    Quote Originally Posted by dammachines View Post
    Hey Caprirs,
    Dave
    I do not know what if any differences there are between the 3000 and 3000H. Neither model was being produced when I worked for Dyna. In fact, there were almost no Mitsubishi machines left, everything was PC control.
    Jun 2010
    45
    The control was a regular desktop pc with hard drive. I just copied the software over to a pentium 2 and put the ISA card into the new one. I also upgraded the software with their latest version that runs my machine. I had to replace 2 eproms in the machine board to do this. I had to send them a photo of my original PC in order to purchase the upgraded software. My led indicators on the pendant quit working at that point, without a solution from Dyna.
    Are you in the Silicon Valley area?
    Roger
    Oct 2005
    672
    I am located in the Phoenix, AZ area.
    You replaced two eproms on the big board in the back cabinet, presumably the DRV and PLC chips. Did they not supply new chips for the keyboard as well? If you open the front pendant and look on the back side of the keyboard, there should be two more chips with stickers with checksums. These would also need to be replaced depending on which version of the software you were running and which you upgraded to.
    Jun 2010
    45
    No, they didn't supply those. I'll post a picture of the pendant. I may have a one off machine...?
    Roger
    Nov 2009
    4415
    I believe you are correct on the difference of the 3000 & 3000H. It seems Roberto confirmed the 3000H did have ballscrews. My 3000 has leadscrews.
    Jun 2006
    3063
    Caprirs,
    Thanks foir the details on the various models that were sold over the years. It's hard to find this sort of thing unless someone like you takes the time to make it available.
    How many lathes that could take 5C collets did Dyna make? From my brief search on the Internet it looks like the 3000 and 3000H were in that class - were/are there others?
    Mike
    Oct 2005
    672
    CNCinCal
    You might have a one-off machine. There were some issues with assuring that machines were consistent when they left Dyna in the early stages of the PC control. It would be worth contacting Dyna to request that you be sent the corresponding eproms for the keyboard. They should have been included with the eproms for the big board in the back cabinet.
    MichaelHenry
    The DL3300 will also accept 5C collets although it was not a benchtop model. The spindle was equipped with a drawtube so that either collets or a jaw chuck could be used. The 3300 was a Mitsubishi controlled machine with either L3 or 520.
    Jun 2006
    3063
    Quote Originally Posted by Caprirs View Post
    Thanks - Mike
    Jan 2021
    4
    Hello,
    I'm looking at a DM 2800 with the color screen controller. I wanted to know if I can program in Master cam and then load onto the Dyna?
    Thank you for any help
    Nov 2012
    361
    Re: General Dyna Mechtronics info
    I can't answer you conclusively (as in, with the confidence that I have done it), but I don't see why you couldn't. The hardest thing will be finding an appropriate post.
  1. Dyna Mechtronics
    By vintageracer in forum Dyna Mechtronics
    Last Post: 01-20-2020, 04:14 PM
  2. Replies: 195
    Last Post: 03-02-2014, 02:17 AM
  3. Dyna Mechtronics 3000H
    By shep640 in forum Dyna Mechtronics
    Last Post: 03-02-2010, 02:32 AM
  4. DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!!
    By britcollector in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:20 AM
  5. DNC on the Dyna Mechtronics
    By Professorwiz in forum DNC Problems and Solutions
    Last Post: 08-11-2005, 05:49 PM
