Hi all.
I have problem with Mazak QT8. After press start, display alarm 293. In documentation code this alarm - optional sensor 4. What is this? Please help me.
Regards
Gelos
Hi all.
Regards
Gelos
Going from memory, I believe the tailstock quill was not homed after E-stop was pushed.
Solution: Extend tailstock quill and then retract it. Should work.
In my machine tailstock is removed. Limit switch in tailstock box was moved. After set the limit switch problem is solved. Very thanks.
