585,679 active members*
5,790 visitors online*
    Mar 2005
    305
    DC Motor in Pallet Jack
    We are scrapping out three 24v electric pallet jacks. The drive motors are 2.4 kw, 24v motors. An online converter shows 2.4kw = 3 hp. In their current usage, they are run at variable speeds. Is there any use for these motors to drive a spindle in a mill or lathe? What are they worth?
    24220
    At 24v they may not offer much flexibility for spindle use.
    Also it would need to be determined if they are Permanent Magnet or wound field, if wound field if a series motor?
    Al.
    Albert E.
    Mar 2005
    305
    Al.
    What do I need to look for to determine if they are permanent magnet or wound?
    How do I check for series on a motor?
    24220
    If wound field, there are two conductors to the field as well as two to the armature.
    If series connected, the two armature leads are in series with the field.
    Wound motors can be series or shunt, P.M. motors are always shunt type and have two armature conductors only.
    Al.
    Albert E.
  1. Moving machinery with a Pallet Jack
    By damae in forum South Bend Machinery
    Last Post: 11-22-2016, 02:14 AM
  2. Help with my pallet jack problem ??
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 02-21-2010, 10:33 PM
  3. Jack Yin Fired
    By Micheal Donnellan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-04-2008, 09:46 AM
  4. Letme introduce you to Jack
    By ynneb in forum Community Club House
    Last Post: 04-03-2005, 01:12 PM
  5. can a car scissor jack for a Z axis?
    By NickLatech in forum DIY CNC Router Table Machines
    Last Post: 01-15-2005, 08:05 PM
