585,894 active members*
4,584 visitors online*
Results 1 to 7 of 7
    Jan 2004
    45
    Lightbulb timing belt reduction
    I have converted a prazi 400 mill to cnc with flashcut stepper drive,using 4:1 timing belt speed reduction on steppers.This gives a max feed rate of 8 in per minute. I have stock acme threaded screws. I went with the 4:1 ratio to give greater positioning accuracy and greater torque at low speeds but clearly rapids are limited by slippage to 8 in per minute.What do you all think ,should i have gone with a lesser ratio? What would be the best compromise between speed and torque?
    746
    You should not be having any slippage if you are using timing belts and pulleys. Is the slippage due to the belt jumping on the sprocket. Do you have enough belt tension. What size/ pitch belt are you using.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Jun 2003
    453
    Are the pulleys securely fixed to the shafts?
    Apr 2005
    20
    Assuming there is no slippage, what stepping do you have? "Drivers are available in full-half step or micro-stepping versions"? What is the lead on your screws VS the max RPM of your output shaft? Hope any of this helps, good luck with it.
    Jan 2004
    45
    slippage
    sorry, slippage is the wrong term, the drives lose steps and accuracy ,i presume due to torque fall off at higher stepper motor speeds.
    Try gearing 2:1 instead.
    Jun 2003
    1365
    You might even want to try 1:1 direct drive. The stepper motors highest torque comes from the lowest rpm and drops off quickly after that.
    It also depends on stepper size and size of the machine.
    Jon
  1. Timing belt length calculator.
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 01-06-2009, 01:54 AM
  2. timing belt question
    By Aegeon in forum DIY CNC Router Table Machines
    Last Post: 05-18-2005, 03:50 PM
  3. Belt reduction questions Please help!?
    By Bird_E in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2004, 02:55 PM
  4. Any recommended Timing belt and pulley?
    By starCNC in forum Uncategorised MetalWorking Machines
    Last Post: 08-01-2004, 05:29 AM
  5. Should you put grease on a timing belt?
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 04-22-2004, 02:54 PM
