585,585 active members*
4,072 visitors online*
    Jun 2010
    software for 6-axis robot
    What soft is capable of creating 6-axis toolpath for industrial robots such as KUKA or ABB? For now I knew only RobotMaster. Is there alternative ?
    I'm a robot system integrator with lots of skills in robot milling both with KUKA and MOTOMAN. I propose and sell a off-line robot simulator and postprocessor called Eureka http://www.redsrl.net/en/products/so...ts/eureka.html ...just have a look.
    Anyway...as a offline simulator software developer with many years of experience I can give you the following list of similar products:
    - Robcad
    - Easy-ROB
    - Delmia
    - Workspace 5
    - Camelot - Robsim
    Hope this helps,
    Milena.
    www.redsrl.net
    Jun 2010
    Hey,
    I think you are referring to RobotMaster which is a plug.in to MasterCAM to generate RAPID code (for ABB robots) from a toolpath created in MasterCAM. MasterCAM is a dedicated CAM software for milling and machining. For certain applications, RobotStudio Machining PowerPac can do the job, but in general RobotStudio is not a CAM software that can replace RobotMaster/MasterCAM, see http://www.mastercam.com/ and http://www.robotmaster.com/
    Hope it helps.
    Maanasi
    Dec 2006
    310
    Dear All
    We have a ABB Robot 44-51739
    After power ON, we keep getting Connecting to Robot Controller and it fails to get connected
    We swithced off, taken out flash card and switched ON, then also we keep getting Connecting to Robot Controller and it fails to get connected, that means presence of Flash card has no effect.
    We could open Flash card in Laptop and find contents inside it to be alright with respect to back up we have
    Can any one of you please advice ????
    Best Regards,
    M. Rishikesh
    Dec 2006
    310
    Dear All
    Compact flash card is causing the problem
    Can any one advice please on how to create boot image for flash card ???? so that flash card becomes bootable
    Best Regards,
    M. Rishikesh
  1. help the robot software
    By newrock in forum RC Robotics and Autonomous Robots
    Last Post: 07-20-2012, 08:23 AM
  2. software to control a 5 or 6 axis welding robot
    By cbucner in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2008, 07:34 AM
  3. Robot arm control software
    By blurrycustoms in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-26-2008, 06:21 PM
  4. software for robot controling
    By FredCNC in forum RC Robotics and Autonomous Robots
    Last Post: 07-25-2006, 08:52 PM
