hello =)
i have for a while been out looking for a milling program, that uses the c-axis as a Y-axis, i have a okuma lb-15II whit an OSP7000L controle panel.
Do any one know where 2 find that ?
Alexz
hello =)
Alexz
hmm its because i shall make some 45angle gear on the okuma. I have made a program that are running fine but the problem are that the gear are missing the 7.2 curve on each tooth.
So i was thinking that there must be a simular program as igf just on the computer.
There is "IGF advanced" PC version.
Still don't understand the way C axis can replace Y axis when cutting 45° gear. It's possible using end mill, simple 3 axis movement if machine specification allows 3 axis cutting. It's helical cutting, optional for simple Okuma M lathe
post print/ pix of the part you talking about.
The best way to learn is trial error.
Are you after some sample code?
NOEX VTLIN[1]=36 VTLFN[1]=1 VTLD[1]=20 VTLL[1]=50
NOEX VWKR=9999.999 VCHKL=0 VCHKD=0 VCHKX=100 VCHKZ=-100
DEF WORK
PT LF,LC,[-100,0],[100,100],[100,0]
END
DEF WORKF
PF 0,[0,0],100,D
END
CLEAR
DRAW
N0001 G00 X300 Z300
N0002 G50 S3800
NAT01
N0100 M110
N0101 G94 M146 M15 M08
N0102 G00 Z3 T010101 SB=1000
N0103 X146.542
N0104 G17
N0105 C5.538 M13
N0106 G01 Z-10 F1000 M147
N0107 M146
N0108 G101 X124.994 C19.842 G41
N0109 G103 X100 C0 L30
N0110 G101 X141.421 C315
N0111 C225
N0112 C135
N0113 C45
N0114 X100 C0
N0115 G103 X124.994 C340.158 L30
N0116 G101 X146.542 C354.462 G40
N0117 G00 Z3 M147
N0118 M146
N0119 G95 M12 M09
N0120 M109
N0121 G00 X300 Z300 T0100
N0122 M02
just curious:
N0102 G00 Z3 T010101 SB=0
N0106 G01 Z-10 F0 M147
the program looks like IGF made. How do You get 0 values there?
Whoops. Fixed now
Also using G137
DEF WORK
END
DEF WORKF
PF 0,[0,0],100,D
END
CLEAR
DRAW
N0001 G00 X500 Z800
N0002 G50 S3800
NAT01
N0100 M110
N0102 G00 Z3 T010101 SB=3183
N0103 X146.542
N0104 G17
N0105 G137 C0
N0106 G00 X72.929 Y7.071
N0107 M13
N0108 G01 Z-10 F2546.4 M147
N0109 M146
N0110 G101 X58.787 Y21.213 G41 F509.2
N0111 G103 X50 Y0 L30
N0112 G101 Y-50
N0113 X-50
N0114 Y50
N0115 X50
N0116 Y0
N0117 G103 X58.787 Y-21.213 L30
N0118 G101 X72.929 Y-7.071 G40
N0119 G00 Z3 M147
N0120 M146
N0121 G136
N0122 G95 M12 M09
N0123 M109
N0124 G00 X500 Z800 T0100
N0125 M02
where can i get the Advanced One Touch IGF - L for pc. i have been trying too google it, but whit out any luck
From your Okuma dealer
Older off-line programming for Okuma was TM-APT ( not on a PC or a Mac, but was a sort of clone of a machine control available only thru Okuma )
now available is ADMAC for mills and/or lathes for running on a PC---still only thru Okuma
try searching for "okuma admac" for more info
sure. A little addition. Both IGF Advanced for PC and Admac are protected by Sentinel based USB (older - LPT port) key
