585,599 active members*
3,665 visitors online*
    Protective shielding tape
    I need to protect the surface from laser cutting effects. Using masking tape gets old quickly when cutting bigger pieces.
    What suggestions do you have for both industrial and for locally available protection film that comes in a wide roll. For example, I am thinking about trying shelf liner and book covering material.
    Bertho
    Hi Bertho,
    The best stuff I have found is the 'transfer tape' used by the sign making industry. Works for me.
    (I also cut sign vinyl (drag knife method) so already have the low tack transfer tape on hand - comes in anything up to 1M wide rolls).
    Tweakie.
    CNC is only limited by our imagination.
    Jul 2008
    776
    Agree with Tweakie, only one addition - keep you attention on fact that you need PAPER-BASED transfer tape. Usually this is cheapest one. Suppliers also can offer plastic-based which is not suitable for your purposes.
    Thanks for the fast replies.
    I will try the suggested paper transfer tape.
    Bertho
  1. My first success with home made protective bellows
    By guru_florida in forum Mechanical Calculations/Engineering Design
    Last Post: 05-14-2013, 12:21 AM
  2. EMI shielding
    By bigalow in forum CNC Machine Related Electronics
    Last Post: 02-29-2008, 03:18 PM
  3. Nylon/Rubber/etc for homemade protective bellows
    By guru_florida in forum Glass, Plastic and Stone
    Last Post: 12-29-2007, 04:18 PM
  4. Replies: 8
    Last Post: 04-09-2007, 06:58 PM
  5. Connection of shielding
    By cncuser1 in forum CNC Machine Related Electronics
    Last Post: 06-18-2006, 01:57 AM
