584,826 active members*
4,985 visitors online*
Thread: alarm 2034
Results 1 to 14 of 14
    Jun 2010
    alarm 2034
    our machine Doosan display alarm 2034 TWOLS ON (LS20,LS21). What is the solution? advice me/
    2932
    What is the model number of the machine? When did the alarm occur?
    please supply the model number!
    this is the same like getting a customer on the phone, that thinks you know every position of every machine in his company.....
    its the machine in the left corner that has the problem....
    without model number is guessing...
    Oct 2009
    30
    Typically a 2034 on a doosan or daewoo is directly
    related to improper positioning of the proximity switches for the chuck.
    Clamp chuck with your part in chuck check for light on switch or x8.3
    if that doesn't work and your NOT using a barfeeder keeprelay 7.6 turns them off I believe.
    Jun 2010
    alarm 2034
    [QUOTE=karthi012;790986]our machine Doosan display alarm 2034 TWOLS ON (LS20,LS21). What is the solution? machine model V84.
    this alarm appear during drilling. this alarm can reset and run the machine again.advice me/
    Oct 2009
    30
    Your proxy switch for chuck clamp must be set right on precipes of on or off or bad prox replace it
    Jun 2010
    doosan v84(milling machine)
    Quote Originally Posted by von007 View Post
    sorry. our macine is milling machine and no using bar feeder.
    Oct 2009
    30
    I'm sorry I don't recognize that alarm on a mill. Please state which control model and machine s/n plz.
    ACE HC = 2034 EXTERNAL COOLANT UNIT ALARM OR LEVEL SWITCH ALARM(CHECK EAXTERNAL COOLANT UNIT OR LEVEL SWITCH X4.6(COL.M))
    DNM = 2034 ATC/COOLANT/LUBRICATION MOTOR OVERLOAD
    ACE DB = 2034 T-S-C FILTER CHANGE OR LOW LEVEL ALARM
    MYNX = 2034 EXTERNAL COOLANT UNIT ALRAM OR LEVEL SWITCH ALRAM
    ACE H100 = 2034 (AL34)PRESSURE SWITCH OF THROUGH THE SPINDLE COOLANT ALARM,CHECK PRESSURE SWITCH(X3.2)
    FYI
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Jan 2016
    Re: alarm 2034
    We have 3 new Puma 2600Y lathes. The 2034 alarm is an external alarm. Chip conveyor e-stop or high pressure coolant e-stop. This alarm just happened today.
    Feb 2013
    788
    Re: alarm 2034
    Quote Originally Posted by chard98 View Post
    See attached.
    Send me an email if it is too small and I'll reply with the full-sized documents
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Jan 2016
    Re: alarm 2034
    Thanks dhardt. I have the electrical manual. What pages are you referencing? The snapshot is a bit blurry. The solution was a remote e-stop on the high pressure coolant pump, it was pushed while removing the chip hopper.
    Feb 2013
    788
    8031, 2021, 2022
    Jan 2016
    Re: alarm 2034
    Thanks very much. I will not the pages for future use.
  1. Replies: 27
    Last Post: 02-09-2022, 05:10 PM
  2. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  3. ALARM 2034 - MOTOR OVERLOAD - DOOSAN PUMA 400L
    By rpm3000 in forum Daewoo/Doosan
    Last Post: 01-21-2014, 11:43 PM
  4. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
