our machine Doosan display alarm 2034 TWOLS ON (LS20,LS21). What is the solution? advice me/
What is the model number of the machine? When did the alarm occur?
please supply the model number!
this is the same like getting a customer on the phone, that thinks you know every position of every machine in his company.....
its the machine in the left corner that has the problem....
without model number is guessing...
Typically a 2034 on a doosan or daewoo is directly
related to improper positioning of the proximity switches for the chuck.
Clamp chuck with your part in chuck check for light on switch or x8.3
if that doesn't work and your NOT using a barfeeder keeprelay 7.6 turns them off I believe.
[QUOTE=karthi012;790986]our machine Doosan display alarm 2034 TWOLS ON (LS20,LS21). What is the solution? machine model V84.
this alarm appear during drilling. this alarm can reset and run the machine again.advice me/
Your proxy switch for chuck clamp must be set right on precipes of on or off or bad prox replace it
I'm sorry I don't recognize that alarm on a mill. Please state which control model and machine s/n plz.
ACE HC = 2034 EXTERNAL COOLANT UNIT ALARM OR LEVEL SWITCH ALARM(CHECK EAXTERNAL COOLANT UNIT OR LEVEL SWITCH X4.6(COL.M))
DNM = 2034 ATC/COOLANT/LUBRICATION MOTOR OVERLOAD
ACE DB = 2034 T-S-C FILTER CHANGE OR LOW LEVEL ALARM
MYNX = 2034 EXTERNAL COOLANT UNIT ALRAM OR LEVEL SWITCH ALRAM
ACE H100 = 2034 (AL34)PRESSURE SWITCH OF THROUGH THE SPINDLE COOLANT ALARM,CHECK PRESSURE SWITCH(X3.2)
FYI
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
We have 3 new Puma 2600Y lathes. The 2034 alarm is an external alarm. Chip conveyor e-stop or high pressure coolant e-stop. This alarm just happened today.
Thanks dhardt. I have the electrical manual. What pages are you referencing? The snapshot is a bit blurry. The solution was a remote e-stop on the high pressure coolant pump, it was pushed while removing the chip hopper.
Doosan Service Technician
[email protected] O:973-618-2461 M:973-803-9479
Thanks very much. I will not the pages for future use.
