585,582 active members*
3,909 visitors online*
    Jun 2010
    Robot Milling
    The rapid prototyping robotized cells are the RED Technologies solution for 3D modeling, milling and cutting based on industrial robots. The high reliability and flexibility of industrial robots are reflected in: high productivity, integrated management of more technological processes, reduced maintenance costs.
    The machine can be programmed as a classic CNC machine. A CAD / CAM system allows the 3D piece modeling and the generation of the working program. These are then imported into a 3D simulation environment, Eureka, to check and manage robot movements and to translate CAM program in robot language. Reduces downtime: the programming is carried out while the machine is productive.
    There are available several hardware solutions depending on the working area and the material to mill.
    Link to the web page: http://www.redsrl.net/en/products/au...pingcells.html
    Link to the product brochure: http://www.redsrl.net/Rapid_prototyping_ENG_web.pdf
    Attached Files Attached Files
    Jun 2010
    The rapid prototyping cell supplied by RED Technologies can mill on: Foam, polyurethane, wood, aluminium.
    Flexibility and high productivity are the best way to a quick return of investment.
    Jun 2010
    RED MILL 165ST is the RED Technologies solution for milling marble and stone.
    it's the evolution of the standard rapid prototyping cell RED 165.
    RED MILL 165ST is powered from Eureka off-line 3D simulation software and has a 12kW spindle, 12000 rpm.
    Jun 2010
    p
  1. CNC Milling with a Fanuc Robot
    By MBX5 in forum MetalWork Discussion
    Last Post: 11-25-2010, 05:49 PM
  2. Cannibalize Industrial Robot Servo System to Retrofit Milling Machine???
    By GM1G in forum RC Robotics and Autonomous Robots
    Last Post: 05-16-2010, 03:53 AM
  3. CNC Robot
    By voltsandbolts in forum Videos
    Last Post: 03-05-2010, 06:06 AM
  4. Looking for Robot Auto Palletising (Panarobo and or STORK Robot)
    By rsarwanto in forum European Club House
    Last Post: 09-12-2008, 12:22 PM
  5. CNC to Robot
    By GT_racing in forum G-Code Programing
    Last Post: 05-24-2006, 02:18 PM
