585,978 active members*
4,441 visitors online*
    Mar 2006
    233
    Setting up G540 with mach 3
    It was late last night when I got my pc up and going with mach 3. I set my parallel port to the correct setting in the bios. I am now wondering what I need to do with that file that is provided for mach 3 to work with the g540 and is there anything else I need to do besides plug it in and start mach 3?
    Apr 2004
    5737
    The XML file?
    Just put it in the Mach3 folder; it should show up as a "profile" in Mach Loader. Choose that when you start up and see if it works.
    Andrew Werby
    www.computersculpture.com
    Mar 2010
    371
    I just did this yesterday.
    You copy the xml as directed. Start the loader, and you will see it.
    You must put the E-Stop circuit in place (or at least connect a wire between the E-stop input and ground). You don't need the home/limit switches to get something to move.
    It "just works" after that, although you will need to put your own values for the steps and such, which depend on your drive components.
    Mar 2006
    233
    MOTHER F'ER!!!!!! My db25 cable is M to F and I need a double F..... off to frys tomorrow on lunch break to get an adapter.......... I cant wait any longer!!!!!!
  1. do you know if the g540 uses the gecko setting?
    By draughted in forum LinuxCNC (formerly EMC2)
    Last Post: 12-20-2012, 05:26 PM
  2. G540 PWM Mach settings
    By skidiiii in forum Gecko Drives
    Last Post: 05-17-2010, 02:14 AM
  3. Newbie Setting Up His G540
    By phil m in forum Gecko Drives
    Last Post: 02-23-2010, 11:14 AM
  4. Replies: 9
    Last Post: 02-04-2010, 04:51 AM
  5. Setting up the G540
    By boxwood in forum Gecko Drives
    Last Post: 09-15-2008, 06:44 PM
