585,975 active members*
4,615 visitors online*
Results 1 to 11 of 11
    Dec 2009
    17
    Barcoding on Polycarbonate by DP Laser
    Hi
    I m thinking of putting 1D barcode on Polycarbonate directly by DP laser.
    Will this be a right means whether Barcode will be scan able....?
    has anybody tried it before. Looking forward to support.
    Regards
    Alok Jha
    Jul 2008
    776
    As I understood - polycarbonate is clear. Are you sure that DP laser will engrave on clear material at all? May be better and cheaper try Co2 laser with galvohead.
    Dec 2009
    17
    Quote Originally Posted by Litografa View Post
    Thanks.
    well I m already marking Polycarbonate with DP laser.(attach please see imgae of DP lasser marking on PC)
    The laser marking is in Crisp Black color on PC, but I have never tried Barcoding on it. I heard that Barcoding requires solid white surface or bright surface , I have doubts on it.
    I hope u understand my concern of outting baroce on low contrast material like Polycarbonate.
    Alok Jha
    Jul 2008
    776
    Perffect black color - I think will be NO PROBLEM with barcoding and reading.
    Dec 2009
    17
    Ok , Let me try. Will update u on results.
    thanks
    Jul 2008
    776
    What is brand of your DP? Very interesting as our was from YM Laser and we can't do anything on clear materials.
    Dec 2009
    17
    Jiatai laser from China
    Dec 2009
    17
    Hi
    I tried Barcoding on Polycarbonate by my DP laser byut failed. It printed but is completely not scan able. eason might be low resolution ogf Polycarbonate material resulting scanner to unable indentify lines in barcodes.
    Secondly as I m printing barcode in size 15 x 10 mm there is not satisfactory spaces left behind bars and the space is filled by micro spores on Laser marked polycarbonate.
    Any suggestions....
    alok
    Jul 2008
    776
    Engrave and after engraving make few moves on engraved area with carbon paper. Will have black and reasonable durable barcode.
    Mar 2009
    31
    I have seen barcodes on stainless steel before so I dont think you need a solid white background. I plan on doing this with my co2 laser with cermark. Though havent a barcode scanner to test it yet.
    You could use a substrate to help define the lines.
    Dec 2008
    1258
    Quote Originally Posted by Magritte View Post
    You DO NOT need black and white, just contrast. The scanner sees reflected light so a change to reflectivity is sufficient. I do 2D barcodes on gold all day long and only remove the oxidation layer. To the eye it isn't very different but the scanners pick it up just fine.
    Zax.
  1. Is anyone laser cutting polycarbonate
    By Psi For Fun in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-30-2022, 08:33 PM
  2. Laser/Waterjet SS 316 5-8mm (0.27/0.33) and 8mm (0.33) Polycarbonate
    By rugludallur in forum Employment Opportunity
    Last Post: 03-15-2010, 11:51 PM
  3. Sub pixel Laser engraving polycarbonate
    By Aquacut in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-14-2010, 11:56 AM
  4. laser sub-engraving inside polycarbonate - safe?
    By Aquacut in forum Glass, Plastic and Stone
    Last Post: 01-14-2010, 08:56 AM
  5. Polycarbonate forming
    By thorsgaard in forum Vacuum forming, Thermoforming etc
    Last Post: 09-21-2007, 11:22 PM
