So this is hopefully a very stupid question, but I cannot find the answer in any of the manuals for this machine. I'm an engineer that's had to get into the dirt of CNC programming.
Where can I find data on how the HAAS controller handles various work offsets. I have a set of simple parts for which I use G110-G112 work offsets.
There seems to be a set of hidden offsets in the machine's computer that I cannot find any data on. Here's a simple run-down of my problem:
1. Select G112 Work Offsets. Go into MDI Mode to run 'G112;' to make sure.
2. Position the table over my physical XY Zero.
3. Use 'Set Part Zero' for both X and Y.
4. Note the X and Y numbers in the OFFSETS Screen for G112.
5. Press the 'POSIT' button. OK, Work Coordinates should be (XY)= 0,0. No.
6. Go into MDI, type in 'G112;' and green button to Run.
7 Back into 'POSIT' Screen. OK, now the Work Coordinates read (XY)= 0,0.
8. This is fine so far.
9. Now, move the table somewhere.
10. Type in a bit of code in MDI mode: 'G112 G92 X0 Y0;'
This should set XY0,0 at current location, which it does.
11. Go back into 'POSIT' screen, sure enough I have Work Corrdinates (G112) reading X=0, Y=0.
12. Go into 'OFFSETS' screen, and the X and Y numbers for G112 are *unchanged* !! This seems wrong!
13. Re-position to physical XY zero position, and use the 'Set Part Zero' to set this location as 0,0. Re-run 'G112' from MDI mode.
14. Now I have X=0, Y=0, but the offset numbers in the 'OFFSETS' screen are completely different from the first time, while XY 0,0 is in the same location.
Can anyone tell me what gives? Is there a resource that explains how the Haas controller deals with Work Coordinate Offsets (something "so easy an engineer can use it!"). The manual and the user interface are inexcusably abysmal, and I'm stuck.
Thanks for any info you all can provide!
