Does anyone sell an extrusion for rocker arms. Thought I saw one at the last Indy PRI Show. You could buy just one bar off their tooling.
What exactally are you looking for as a shape? I may be able to help you out.
I want to make some roller rockers for cylinder heads. I need a bar that I cut off for the width that I want. Could send a picture if you want.
What are the dimensions of the extrusion you are looking for? I work for a rocker arm manufacturer and have several different extrusions, I can make the rockers for you also if you are interested. You are also going to need pins,rollers,trunions, and a pushrod seat cup or an adjuster. I have all these parts available if you need to buy them or like I said I can make the rockers for you and they will be completely assembled when you get them.
