584,837 active members*
5,380 visitors online*
Thread: V-Carve
Results 1 to 6 of 6
    Feb 2010
    V-Carve
    Hello,
    Has anyone used the V-Carve tool path command. I am thinking of upgrading. Is it as simple as defining a closed shape and tool, then letting the program do the depth calculations? How does it compare to Vectric V-Carve Pro?
    Mar 2009
    1114
    You sure your in the right place?
    Feb 2010
    Yes, Bobcad has V-carve.
    Mar 2009
    1114
    Oops my mistake I read it wrong.
    Feb 2007
    505
    Wink vcarve
    Ver 23 ,with its job tree, in my opinion is quite an improvement over Ver 21.
    Vcarving is working fine. Vetric has the option of making a final pass of let say .05 per example. witch is better when working with hard wood I find.Beside that I think its well worth the money.
    I ve been only using the trial version of vetric though.
    P.S. I got an incredible deal on ver23 at the very end of the year.
    Feb 2010
    Thanks Claude.
  1. v-carve
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 03-30-2010, 03:13 PM
  2. V carve pro, can it do this
    By andyclarke in forum PhotoVCarve and VCarve Pro
    Last Post: 08-15-2009, 05:04 AM
  3. v-carve in mm
    By serocco in forum Vectric
    Last Post: 02-13-2008, 12:13 PM
  4. V Carve
    By tangocc35 in forum Joes CNC Model 2006
    Last Post: 10-17-2007, 09:18 PM
  5. V Carve possible changes
    By Brian P in forum Vectric
    Last Post: 09-11-2006, 09:32 PM
