585,722 active members*
4,286 visitors online*
    May 2010
    taig mill belt tension
    Hi, i bought a taig mill but do not know how to adjust the belt tension. how tight it should be? i notice a bit of vib when i put my hand on the headstock. if the belt is tight, should i adjust the belt so i will feel not viberation on the headstock? i can always feel a bit of vib with my hand on the motor. searched a lot but did not find any instruction. thanks a lot!
    Apr 2004
    5734
    It should be pretty tight
    If you poke it with your finger, it shouldn't deflect more than about 1/4" (that's half a centimeter or so). The important thing is to get the pulleys exactly level, so the belt's not stressed on one side more than on the other.
    I'm not sure what vibration you're talking about, but there shouldn't be much of that in the motor or the spindle. Is this the stock Taig motor you're using, or something else?
    Andrew Werby
    www.computersculpture.com
    May 2010
    thanks awerby
    thanks mate. did what you suggested and the had stock is very still now. it was too tight. i am using a stock taig with cnc. cheers!:rainfro:
  1. Taig CNC Mill Belt problem
    By ecope in forum Taig Mills / Lathes
    Last Post: 04-27-2010, 04:42 AM
  2. at5 25 wide timing belt tension?
    By DanOSB in forum Linear and Rotary Motion
    Last Post: 09-27-2009, 05:45 PM
  3. Belt Tension Options??
    By flash319 in forum DIY CNC Router Table Machines
    Last Post: 09-19-2007, 08:06 PM
  4. Timing belt tension requirements vs backlash
    By jensor in forum Mechanical Calculations/Engineering Design
    Last Post: 05-20-2007, 08:04 PM
  5. Belt Tension Adjuster Design
    By mxtras in forum Mechanical Calculations/Engineering Design
    Last Post: 05-16-2005, 04:33 PM
