585,728 active members*
4,117 visitors online*
    Jul 2003
    69
    Heidenhain CYCLE 19 Work Plane Tilt
    I'm looking at cutting a dovetail that is tilted 10 degrees to the X-Y plane on the X-axis. I was wondering if someone could explain how the CYCLE 19 Working Plane function works. The machine is a 5-axis machine with a nutating head (B & C axis, with an A-axis rotary on X-axis). The control is a TNC 530, we also have a TNC 426 on a similar machine. Do I program the dovetail as if it was on the X-Y plane then tilt the B-axis 10 degrees & call the CYCLE 19 Work Plane Tilt & the control will take care of the change in coordinates or do I have to calculate the new coordinates based on the 10 degree tilt ?. Any & all input would be appreciated as I am very new to this 5-axis stuff.
    Thanks.
    Jul 2008
    7
    Quote Originally Posted by ED209 View Post
    Thanks.
    Cycle 19 is good but plane spatial is better. Try to use plane spatial and you'll find that it's better and easier than 19.
  1. Heidenhain iTNC 530 G200(pecking cycle)
    By DULING in forum G-Code Programing
    Last Post: 02-03-2011, 04:27 AM
  2. Probing cycle ( heidenhain 530 )
    By mrdom in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-04-2009, 08:18 AM
  3. Heidenhain iTNC530, how to change plane?
    By Martynas2 in forum G-Code Programing
    Last Post: 11-23-2008, 04:58 PM
  4. Mill/turn Multi axis work plane question
    By bassn_07 in forum Esprit
    Last Post: 06-01-2008, 09:07 AM
  5. Help Tapping Cycle. Coolant off Heidenhain
    By Roni in forum MetalWork Discussion
    Last Post: 03-10-2007, 08:22 AM
