585,741 active members*
5,039 visitors online*
IndustryArena Forum > Hobby Projects > Steam and Stirling Engines > High Temp Epoxy Piston Rings????
Results 1 to 1 of 1
    Nov 2009
    105
    Greetings, I am starting a project using a 2 cylinder V air compressor to try to convert it to Alpha Stirling. I found some links were small projects created there own pistons using high temp epoxy. Using their idea, I am going to try to replace the piston rings with high temp epoxy and add a dry lubricant between the high temp epoxy rings Hopefully this will give a good seal and reduce friction. Has anyone tried this before? Best regards
  1. carbon filled ptfe piston rings?
    By samco in forum Community Club House
    Last Post: 07-27-2012, 08:05 PM
  2. Looking for quotes for high temp alloys
    By Foxwood in forum Employment Opportunity
    Last Post: 05-19-2009, 05:24 PM
  3. High Temp Tape Residue
    By rcazwillis in forum Mass finishing equipment/media/strategies
    Last Post: 02-04-2006, 12:47 AM
  4. spindle temp, motor temp.
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 07-20-2004, 03:09 PM
  5. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
