Hello all!
I've got a machine that has four separate stations in it, and is run by a 30i controller.
I've had problems with one of ther servo axes, run by an A06B-6127-H105. It was giving me an OH (overheat) alarm. This would come up intermittently, so we decided to swap with another amp of the exact same kind to see if the error followed.
We were getting an "8." on the amplifier itself, which is an overheat, and this matchd what the 30i was saying.
When we did the swap, we got alarm SV1068 on all four stations. This is the "Dual Check Safety" alarm. We also got the "SV0478 Illegal Axis Data (SV)" and "SV0496 Illegal Axis Data (CNC)" when we swapped cards.
What??
We have always swapped amplifiers in the past on other machines to see if we can make the problem follow, but usually it is a simple case of just switching the amps and away we go.
We also got a new amp in, and upon installing it in the defective card's slot, we get the same errors.
Can anyone tell me what is going on with this??
Also, can you point me to where I can find a pdf manual for this amplifier?
