585,992 active members*
6,351 visitors online*
Page 3 of 76 123451353
Results 41 to 60 of 1506
  1. #41
    May 2006
    1469
    Quote Originally Posted by Arbo View Post
    Oh sorry, I thought Gerry had written that post... mind blank.
    You were not allowing for the possibility of a G91 modal state. Most likely why you were getting errors.
    Check for PM
    Greg
  2. #42
    Diagnostics screen
    Still need to add a few more things, but looks good so far.
  3. #43
    Jan 2008
    932
    No comprehend the G91 thing... But currently that line is disconnected from my G540 because of the trouble I had, figured now I'd wait for this screen set to use the new zero stuff, as the way it functions is what I need. Thanks.
  4. #44
    May 2006
    1469
    No worries.
    Gerry does good work so you should enjoy it.
    Greg
  5. #45
    Aug 2007
    558
    Don't know how I missed this thread for so long! I'm still using and liking your Aqua screen set so I'm really looking forward to trying this one too. Let us know where to go to buy it. I'd be up for the 4 axis one, actually wondering whether there's any chance of a 5 axis version?
    Best regards,
    Jason
  6. #46
    Quote Originally Posted by Jason3 View Post
    Best regards,
    Jason
    Can you live with smaller DRO's?
  7. #47
    Nov 2004
    436
    Ger,
    Diagnostic flyout looks great. I will be replacing a few of the leds (dust boot position, tool in sensor, etc), but everything is looking fantastic.
    Thank you for working on this for us!
    BTW, does anyone have experience changing the colors of the background and toolpath? I wanted to try to make it look like default rhino, with a gray background. It appears when I change that setting, that it is really a "foreground", changing the tint of everything. Just a curiosity...
    Rob
  8. #48
    Aug 2007
    558
    Yes, I'd be happy with that
  9. #49
    Quote Originally Posted by spoiledbrat View Post
    Ger,
    Rob
    How many more LED's do you need? I can add some unlabeled ones. All inputs, or outputs too?
    You can't change the background, I've asked about it before. You should be able to in the next version, but it doesn't work correctly now. I think I tried it when you mentioned white background a few months ago. I asked on the Yahoo group, and was told "no dice".
  10. #50
    Jason, which 5 axis?
    X Y Z A B?
  11. #51
    Aug 2007
    558
    X Y Z A B?
    Yes, perfect.
  12. #52
    It was brought to my attention that I left out the Scale DRO's, which I had intended to have. So, I made a change and eliminated the User Tab.
    Also, I found that the TAB flyout I'm using for Diagnostics uses the entire height of the screen, whether you want to or not. So, I rearranged it into a taller, narrower screen. With the diagnostics open, you can still see most of the toolpath, and you can open, close and edit files with the diagnostic screen open.
  13. #53
    Jan 2008
    932
    Looks good, can't wait to get it and start using it.
    Does anyone actually use the scale stuff?
  14. #54
    One of my testers does.
    I still need to put a "global" scale LED on the main page so you know if you have any axis scaling enabled.
    Also just changed the filename to display the name only, instead of the full path.
  15. #55
    4 Axis sample
  16. #56
    Apr 2006
    3498
    wow..Gerry the screen comes out really great
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  17. #57
    Thanks. I like it too.
    It's just about done. I'll post an updated pic tonight as I re-arranged the toolbar two days ago.
  18. #58
    Jan 2008
    932
    I'm ready for it. Just hooked up my probe line again and tested the process with the blue screen. Seems to work like a champ. Now to run out and get some new MDF to replace my chewed up table base and embed a piece of copper in a spot.
  19. #59
    My intent is to modify the M6 End macro, so tool changes are more "automatic" than with the modified Blue screen.
    There's a button for the initial Auto Zero, but the second button won't be needed if you call an M6, as the code will be in the macro.
    If you prefer to manually call the second macro with a button, I'll make an alternate version and replace the M6 button with the second button.
    There shouldn't be any more changes from this. At least I hope not.
  20. #60
    Jan 2008
    932
    My brain is mush from today. So I don't know if I follow.
    But it sounds like if I generate my gcode and it put's an M6 in for tool change, then it would go to a predetermined spot to change the tool, then when that's done I'd hit cycle start, it would take the new bit down to the fixed plate and do it's magic, then it would spin up the router and continue on with the new bit?
    That works for me.
    However, I'd like to have the second button in there for times when I might not generate all the code in one file..
    Am I following or making sense?
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
