584,837 active members*
4,895 visitors online*
Page 59 of 76 949575859606169
Results 1,161 to 1,180 of 1506
  1. #1161
    Sep 2011
    1183
    Re: Mach3 2010 Screen set
    Thank you Gerry my old desktop running XP is making weird sounds so I may have to go to a laptop running windows 7..
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  2. #1162
    Jan 2008
    241
    OK, try this.
    Don't use the Initial Auto Zero anymore, as you no longer need to save the location of the fixed plate.
    Just use the Simple Auto Zero to start, and during tool changes, this should basically just do another auto zero to the fixed plate.
    This hasn't been tested, so be careful with it.
    Thanks Gerry, I wont have time for the next couple of days, when I do, I'll let you know the outcome.
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
  3. #1163
    Dec 2007
    101
    I use Gerry's screen set with a touch screen and it works fine. I do have small hands though.
  4. #1164
    Mar 2010
    813
    Quote Originally Posted by Mogal View Post
    I haven't had a chance to try yet also. Been busy upgrading my computer to run Marh3 and now waiting on my Spoilboard surface cutter. I'm extremely anxious to try out the macro Gerry generously supplied. What I'm hoping to accomplish is eliminating my movable plate and just use fixed plate for table zero and use the material offset for whatever thickness material I'm cutting.
  5. #1165
    Just want to clarify something with that macro. It still uses the plate thickness from the toolchange tab, so if the plate is flush with the spoilboard, enter 0 for the plate thickness.
  6. #1166
    Mar 2010
    813
    That's a great idea, that way I wouldn't have to remove if I needed the full length of table to cut something.
  7. #1167
    Sep 2013
    8
    Hey Gerry,
    First of all thanks for the guidance on feeds and speeds over at the Joe's CNC forum.
    I did have a question about your 2010 Screenset that I'm using. It's great, and the semi automatic toolchanger is awesome! But I'm having some issues with the park command at the end of programs. When the M883 macro gets called, the Z-axis moves upward until it hits the limit switch. I have the park settings configured to -0.5 on the Z-axis, so I'm not sure why it's not acting like it should.
    Any help or guidance is greatly appreciated!
    -Kevin
  8. #1168
    Do you have the Machine Coordinates box checked?
    Do you have Use Safe Z checked?
    What version of Mach3?
  9. #1169
    Sep 2013
    8
    I do have Machine Coordinates checked, as that seems like it would be the right setting to use. I want the Z-axis to move just under the top of its travel.
    I have Use Safe Z checked as well, as I believe that causes the Z-axis to retract before doing any X or Y axis moves to the Park Position.
    My machine is running Mach3 3.043.062, which is the version recommended by Warp9 for their Ethernet SmoothStepper that I am also using.
  10. #1170
    What do your Safe Z settings look like? You probably need to change Safe Z to use Machine Coordinates.
  11. #1171
    Sep 2013
    8
    I don't have my machine in front of me, but I'll have a look at it as soon as I get a chance. I'm pretty sure I have it set to machine coordinates, but from looking at screenshots from Mach3 I'm wondering if I have SafeZ set to a positive value instead of negative. That would explain why it's hitting the limit switch.
  12. #1172
    That's what I think is happening.
  13. #1173
    Jan 2008
    932
    Gerry,
    Went to win 7 32 bit, everything seems to work with the screen set. EXCEPT... the edit button. I used to be able to hit that and it would bring up the gcode in a text editor. now it doesn't do anything. Was trying to find a setting to set what editor to use thinking maybe that was it. Couldn't find a setting and couldn't find a macro that is used by that button.
    Wood neophyte.
  14. #1174
    In General Config, do you have a path to an editor configured?
  15. #1175
    Jan 2008
    932
    Thought I looked there, will double check.
    Wood neophyte.
  16. #1176
    Mar 2015
    7
    Hi Guys
    First time poster in this thread so please be gentle....
    I am having trouble getting reliable probing results from my mach3 2010 screenset when using the center finder probe with my makers guide triple edge finder.
    It works perfect every time when setting Z zero but its hit and miss with the center finder from the probing page.
    It will start the procedure just fine until it touches the first edge then it pauses and then all three axis move at the same time in a jerky motion. It often find the first edge pauses and then starts moving in the same direction in a jerky motion. i have to be careful when testing as it could easily lead to damage.
    Sometimes it finds two sides of the circle but then goes nuts. Very occasionally it will work just fine, sadly not often enough to use the feature.
    The probe is being sensed just fine or so it seems as the indicator light shows up reliably when the edge finder is touched against the bit.
    I have added the small capacitor across the probe leads on the breakout board and that didn't help so i added a second one in parallel with no luck.
    The capacitors i used were 0.01uF 50V DIP Low Voltage Ceramic Disc Capacitors
    I'm using an old PC running XP and Mach 3 Version R3.043.066
    I am using a clean bit without any burnt material on it and the software seems to reliably sense the probe as the green indicator lights up.
    Any suggestions guys?
    Thanks in advance
    Ben
  17. #1177
    The first thing I would try is changing to version 3.043.062, as 3.043.066 is very buggy.
    You can get it at the FTPp site:
    ftp://anonymous:[email protected]/
    I'm assuming that you're using the parallel port?
    If version .062 does not help, open Windows Task Manager while probing and monitor the CPU usage, and let me know what it is.
  18. #1178
    Mar 2015
    7
    Thanks Gerry
    I have downloaded version.062 and will install tonight and report back
    oh and yes i am using the native parrallel port
    Cheers
    Ben
  19. #1179
    Oct 2006
    259
    Hi Gerry !!
    Laser Crosshair Setup question !
    New to this as I just installed some Laser Crosshairs, i've got some questions on this setup !?
    When I reed from your manuel ;
    "Modify the offset values to match the offset distances (from laser to spindle) on your machine. Then save
    the macro.
    When the button is pushed, the DRO's will be set to the offset values, which will place the 0,0 position at
    the point of the laser crosshair."....That's very straightforward and seems fine to me !
    What I'm wondering.....( or is it something I'm not...seeing / understanding !?)....
    When i push the Laser Crosshair button, yes the DRO is set to my "offset" values, but....I must "repush" the GO TO Zero button so it can reposition accordingly !...Right !?
    My Question....If this is fine ?.....isn't there a way to set / reprogram this so, when I push the Laser Crosshair button....all this is done and ready to go all in one ?!
    Hopping this is not another repeated question / solution request.....as I did try the search post before taking time to post this. If there is already post on this, could you either, leed me to those or reply here !
    Thanks in advance to help me out !!
    Later, Robert
  20. #1180
    XOffset = 3.43 'X offset from laser crosshair to spindle
    YOffset = 4.322 'Y offset from laser crosshair to spindle
    SetOEMDRO(800,XOffset)
    SetOEMDRO(801,YOffset)
    Sleep(125)
    Code "G0 X0 Y0"
    While IsMoving()
    Wend
    Code "G0 Z0"
    While IsMoving()
    Wend
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
