We got a #379 Battery Malfunction Alarm (TAIL)
According to the manual it says to replace the battery, but we have no idea where the battery is located at. it is a Mazak Nexus 200
Any help??
Any help??
I can see by the date that this is old but i thought I'd answer anyway for someone else who is looking for the answer. If you open up the electrical panel on the back there are some little boxes with red led displays on them one will be flashing al for alarm. Pull off the cover and there will be a Mitsubishi battery that you need to replace. Remember if you turn off the machine some parameters may end up needing reset so order your battery and leave it on until you have finished installing the new one.
