586,024 active members*
4,232 visitors online*
Results 1 to 11 of 11
    Jan 2009
    396
    too fast for pulley issue
    guys what does too fast for pulley means? I'm not even using pulleys!
    24221
    In what context? Where did you hear it from?
    Al.
    Albert E.
    Jan 2009
    396
    it's in mach3 screen down at the bottom it says that
    Go to Config > Spindle Pulleys and increase the max rpm and the message will disappear.
    Jan 2009
    396
    Thank you so much guys!
    Jun 2009
    267
    Ger, Im just testing out Mach trying to get a feel for it and I too am getting this same message. However I dont see "Spindle Pulleys" under config. I do see "Calibrate Spindle" and I have changed those numbers a bunch of times but it keeps defaulting for some reason.
    I don't have Mach3 here, but under the Config menu, there should be a "Spindle Pulleys" listed. What version of Mach3?
    Jun 2009
    267
    Its Mach3 Version R1.83.027. All I see is "Calibrate Spindles".
    Why are you testing a version that was released about 7 years ago??? That's why you can't find the pulley option.
    Jun 2009
    267
    Wow had no idea it was that old of a version. I got it along with some cad and other software I bought off a friend a couple years ago and thought at the time it was the current version. So I knew it was a couple of years old but not 7!! LOL
    At any rate it runs fine on my system. No problems that I have seen so far so Im going to keep it until that changes.
    Feb 2020
    Re: too fast for pulley issue
  1. Lazy Cam not posting Fast Travel as Fast Travel
    By astainless in forum Uncategorised CAM Discussion
    Last Post: 02-24-2010, 09:31 PM
  2. pulley
    By mars in forum Mechanical Calculations/Engineering Design
    Last Post: 05-31-2009, 08:41 AM
  3. Pulley set
    By theclive in forum I.C. Engines
    Last Post: 08-22-2007, 04:56 PM
  4. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
  5. pulley help!
    By DrStein99 in forum RC Robotics and Autonomous Robots
    Last Post: 01-24-2006, 02:44 PM
