Z Axis Backlash
My NM-135 has developed quite a bit of play or backlash in the Z axis. If and when I get the proper x axis lead screw, I will tear the machine down and fix as many of the problems as possible all at once. In the meantime, I need a temporary solution for the Z problem, so I thought I would ask here.
I would like to slow down the rapid setting on the Z axis only, in order to lessen the shock on the system and buy me some time. Does anyone know if there is a way to do this easily in Mach3?
Thanks for any suggestions you have, -Greg
"If Necessity is the Mother of Invention, then Who's the Father?"
